Oem Honda or wiseco?
Old Apr 9, 2007 | 10:47 AM
michielGSR's Avatar
Default Oem Honda or wiseco?
Hi guys,
I am going to rebuild my b18c gsr engine. I will use ITR cams, valve springs, retainers and valves. What pistons do you think I should get? JDM ITR pistons (CR 11,34:1) or Wiseco pistons? Wiseco pistons have a CR around 12:1. Is that usefull with ITR cams?
Thanks for your advise
Michiel
Old Apr 9, 2007 | 11:51 AM
michielGSR's Avatar
Default Re: Oem Honda or wiseco? (michielGSR)
anyone?
Old Apr 9, 2007 | 11:58 AM
doood's Avatar
been there done that
p73 or p30's will be fine
Old Apr 9, 2007 | 01:33 PM
sauceja's Avatar
Default Re: Oem Honda or wiseco? (doood)
P30's will give you about 11.5:1 and are 269.00 from HMO with new OEM rings and wrist pins.
Wiseco will require a different rod as they are forged and have a floating wrist pin.
To stay OEM I would go P30 P73 JDM P73 USDM and PR3 in compression ratio from left to right.
GSR block with P30 and PR3 Head will be around 11.5:1 add some flat faced valves and it will get you around 11.8 - 12.0:1 ratio roughly.
Old Apr 10, 2007 | 03:38 AM
michielGSR's Avatar
Default Re: Oem Honda or wiseco? (sauceja)
ok, so p30 = 11,5:1 and p73 jdm = 11,4:1 ?
93dx--hatch
Jul 2, 2005 05:51 PM
HondaGuy02
Jun 27, 2005 04:01 PM
impound
Jan 16, 2005 11:04 AM
jeremy.
17
Oct 21, 2004 10:34 PM
swarsing
Jun 12, 2002 01:53 PM
