GARAGE SALE ========= ek/dc stuff. mounts, covers, pulleys, swaybars, seats, intakes, throttle bodie
Old Apr 9, 2007 | 09:15 AM
portfl0w's Avatar
Default GARAGE SALE ========= ek/dc stuff. mounts, covers, pulleys, swaybars, seats, intakes, throttle bodie
somebody hit me up before, forgot who it was wanting to trade a blox intake mani for somethin, if not lookin to trade if you guys like anything for a intake mani for gsr, and header for b series. no rush lookin for something cheap/free nothin racey, its a DD. thanks!
stuff thats left over...
LOCAL PICK UP ONLY NO SHIPPING
Local pick up only.
1998 gsr ecu obd2a $100 (i have another one in a p2e case and has a primary o2 heater circuit cel $30)
left ek 99-00 front fender slight dents $20
b16 cams $50 (with gears)
b16 cam gears $15
b series into ek rear mount $45
ek upper drivers side mount, came off my d16 but pretty sure its the same for b16
civic si trans motor mount $30
civic si a/c motor mount starting to crack on one arm, not all the way 25
d16 ek trans motor mount bracket $30
d16 alternator bracket $20
gsr a/c bracket $30 === reduced 25, i got like 2 or 3 of these bad boys
b series alternater lower bracket $15
b series clutch and pressure plate $15
b16 intake manifold $25
b series valve cover hot tanked and sprayed gray $45
integra cruise control unit $25
integra? fuel pump bracket $15
used brake pads pretty sure its for dc front and rear about 40% front 85% rears $5
unknows clips, DC? $5
exhaust manifolds $15 each
lug nuts set of 20 never used brand new with lock 20x34 $10 (different bolt pattern than honda)
d16 shift linkage EK with energy suspension bushings $50
d16 ek fuel line $15
ek brake master cylinder $35
a/c high pressure line ek $15
ek lx rear drum brake proportioning valve $15
b16 throttle cable $20
slave cylinder $30
d16y7 intake box and throttle box with pipe $45
shifter, da?? $5
d16 ek axles tear in one boot no clicks $30
volvo S60R headlight and hid's with bulbs and ballast resistors i have a set of these they work fine shoot me offers
4 door ek rear seats, one cig burn, comes with everything. dog got at one of the side cusions and ate some foam, can be fixed $50
ek under radio dash garnish grey $15
civic si muffler slight bend on inlet hose $30 (40 with si tip)
s2000 rear shocks $75
stock civic springs great condition set of 4 $65
obd0 vtec solenoid $50 sory no pics
2000 civic si front sway bar $50
1985 suzuki lt 250R 2 stroke upgraded wiseco piston NEW low hours, green stickered till 2008 comes with an 2 extra sets of rims and tires, one are wholeshots, the other are sand paddles, can include a trailer if interested $1800
more pics, 2005 volvo S60R hid's ballast resistors, bulbs, casing, heatsinks, make me an offer.
2007 volvo s40 projector with bulb make me an offer, ive also got a 2005 volvo c70 fog light projector, its small and in great condition, i was gona put it on my mini bike ducati style
96+ ek d16y7 stock muffler, and silencer, 30 for both. also have a oem civic si exhaust tip. 15, or included with the si muffler for 40. Thanks guys!
Modified by portfl0w at 2:34 PM 4/9/2007
Modified by portfl0w at 2:37 PM 4/9/2007
Modified by portfl0w at 2:45 PM 4/9/2007
Modified by portfl0w at 2:53 PM 4/9/2007
Modified by portfl0w at 3:50 PM 4/9/2007
Modified by portfl0w at 2:14 AM 4/10/2007
Modified by portfl0w at 2:42 AM 4/10/2007
Modified by portfl0w at 2:55 AM 4/10/2007
Modified by portfl0w at 3:01 AM 4/10/2007
Modified by portfl0w at 2:29 PM 4/10/2007
Modified by portfl0w at 8:30 PM 4/10/2007
Modified by portfl0w at 9:12 PM 4/10/2007
Modified by portfl0w at 9:34 PM 4/11/2007
Modified by portfl0w at 9:35 PM 4/11/2007
Modified by portfl0w at 8:36 PM 4/12/2007
Modified by portfl0w at 12:18 AM 4/13/2007
Modified by portfl0w at 2:55 AM 4/13/2007
Modified by portfl0w at 9:12 PM 4/13/2007
Modified by portfl0w at 1:34 AM 4/14/2007
Modified by portfl0w at 9:50 PM 4/14/2007
Modified by portfl0w at 3:37 AM 4/15/2007
Modified by portfl0w at 5:25 PM 4/16/2007
Modified by portfl0w at 12:40 AM 4/17/2007
Modified by portfl0w at 12:43 AM 4/17/2007
Modified by portfl0w at 12:44 AM 4/17/2007
Modified by portfl0w at 12:53 AM 4/17/2007
Modified by portfl0w at 12:58 AM 4/17/2007
Modified by portfl0w at 1:02 AM 4/17/2007
Modified by portfl0w at 3:00 PM 4/17/2007
Modified by portfl0w at 1:38 AM 4/18/2007
Modified by portfl0w at 2:15 AM 4/18/2007
Modified by portfl0w at 12:01 AM 4/19/2007
Modified by portfl0w at 10:57 PM 4/19/2007
Modified by portfl0w at 11:11 PM 4/19/2007
Modified by portfl0w at 3:49 PM 4/21/2007
Modified by portfl0w at 11:47 PM 4/22/2007
Modified by portfl0w at 5:33 PM 4/23/2007
Modified by portfl0w at 2:59 PM 4/24/2007
Modified by portfl0w at 7:55 PM 4/24/2007
Modified by portfl0w at 10:10 PM 4/24/2007
Modified by portfl0w at 11:21 PM 4/24/2007
Modified by portfl0w at 5:43 PM 4/25/2007
Modified by portfl0w at 12:38 PM 4/27/2007
Modified by portfl0w at 5:07 PM 5/2/2007
Modified by portfl0w at 5:57 PM 5/7/2007
Modified by portfl0w at 4:32 PM 5/16/2007
Modified by portfl0w at 5:13 PM 5/18/2007
Modified by portfl0w at 1:17 PM 5/28/2007
Modified by portfl0w at 11:21 PM 6/2/2007
Modified by portfl0w at 11:24 PM 6/2/2007
Modified by portfl0w at 6:00 PM 6/13/2007
Modified by portfl0w at 11:34 PM 6/25/2007
Modified by portfl0w at 1:29 AM 6/28/2007
Modified by portfl0w at 1:31 AM 6/28/2007
Modified by portfl0w at 4:38 PM 7/4/2007
Modified by portfl0w at 10:11 PM 7/6/2007
Modified by portfl0w at 12:28 PM 7/7/2007
Modified by portfl0w at 1:03 PM 7/18/2007
Modified by portfl0w at 2:28 AM 7/30/2007
Modified by portfl0w at 4:23 PM 8/14/2007
Modified by portfl0w at 6:11 AM 10/29/2007
Modified by portfl0w at 5:06 PM 11/1/2007
Modified by portfl0w at 5:15 PM 11/13/2007
Old Apr 9, 2007 | 09:46 AM
pdotjones's Avatar
Default Re: GARAGE SALE ========= ek/dc stuff. mounts, covers, pulleys, swaybars, seats, intakes, throttle b
pm'd
Old Apr 9, 2007 | 12:10 PM
Sundown's Avatar
pm'd..
Old Apr 9, 2007 | 01:31 PM
portfl0w's Avatar
Default Re: (Sundown)
replied!
Old Apr 9, 2007 | 01:40 PM
Harryflores's Avatar
Default Re: (portfl0w)
I need more specs on the Apex and better pics !! serious buyer!
Old Apr 9, 2007 | 01:53 PM
portfl0w's Avatar
Default Re: (Harryflores)
posted more pics homie
Old Apr 9, 2007 | 01:59 PM
Pm'd
Old Apr 9, 2007 | 05:47 PM
portfl0w's Avatar
pms replied
Old Apr 9, 2007 | 09:42 PM
Bump.... good prices !!
Old Apr 9, 2007 | 09:43 PM
portfl0w's Avatar
all pms replied! thanks alot guys bump it up
Old Apr 9, 2007 | 09:57 PM
portfl0w's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harryflores &raquo;</TD></TR><TR><TD CLASS="quote">Bump.... good prices !!</TD></TR></TABLE>
thanks man! i got more mounts ill try to get em soon
Old Apr 10, 2007 | 12:36 AM
portfl0w's Avatar
nite guys!
Old Apr 10, 2007 | 02:02 AM
portfl0w's Avatar
posted new pics before bed
Old Apr 10, 2007 | 02:07 AM
portfl0w's Avatar
Modified by portfl0w at 8:34 AM 4/17/2007
Old Apr 10, 2007 | 08:47 AM
portfl0w's Avatar
Old Apr 10, 2007 | 09:00 AM
89efDUSTY's Avatar
bump cause i think that box says Asian express
Old Apr 10, 2007 | 10:59 AM
portfl0w's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote">bump cause i think that box says Asian express </TD></TR></TABLE>
haha, observant.
Old Apr 10, 2007 | 01:17 PM
portfl0w's Avatar
hey guys also got another vtec solenoid not cracked, 50, and another cracked on 35. i got more mounts, glanced at em today but didnt shoot pics, i saw a gsr timing belt side mount, another ek timing side mount with both studs, another gsr a/c bracket. a p30 b16 ac bracket, both with pulleys, and another rear mount, possibly ls,gsr,ek. ill snap some pics when i get time. also have a bunch of diff connectors for various wiring harnesses, lemme know what connectors you need 5 bucks a piece. umm... what else. im gonna have a full set of civic lx brakes soon, front control arms, spindles, calipers rotors, swaybar, rear trailing arms, drums and the lines, shoot me offers on that one. theres more but cant remember for now, but im looking for an ac low pressure line off of a gsr or civic si! also a gsr fuel line from filter to rail. civic si stock airbox upper lower and the arm... thanks guys! bump it up
Old Apr 10, 2007 | 01:23 PM
portfl0w's Avatar
Old Apr 10, 2007 | 03:17 PM
efrex's Avatar
Old Apr 10, 2007 | 03:22 PM
portfl0w's Avatar
thanks man!
Old Apr 10, 2007 | 08:28 PM
portfl0w's Avatar
bump
Old Apr 10, 2007 | 08:40 PM
akmi_1's Avatar
BUMP...
Old Apr 10, 2007 | 10:44 PM
portfl0w's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akmi_1 &raquo;</TD></TR><TR><TD CLASS="quote">BUMP...</TD></TR></TABLE>
thank you thank you!
Old Apr 11, 2007 | 12:55 AM
portfl0w's Avatar
nite yall
