Cam Seal / Valve or Head cover replacement.
i bought my 98 LS TEG with 65k miles about 6 months ago from a woman who had owned and dealer serviced it for 9 years. i got every single receipt to prove it!!!
So last week i noticed that my cam seal is starting to tell me that its tired of me pushing its limit
and needs to be replaced.. i bought my fancy aluminum Golden Eagle cam seal, oem honda head cover gaskets, and some hondabond...
I was wondering if any of you "HELMS OWNERS" could tell me if the vtec Head Cover/Cam Seal plate bolts Torque Specs differ from the LS head cover/cam seal plate torque specs. i was reading a post on team-integra.net with diagrams and it noted that the non vtec torque specs will be different. http://www.team-integra.net/se...D=613
Can someone tell me what the manual states for Non Vtec/98LS???
Modified by sidesi at 7:44 PM 4/9/2007
and needs to be replaced.. i bought my fancy aluminum Golden Eagle cam seal, oem honda head cover gaskets, and some hondabond...I was wondering if any of you "HELMS OWNERS" could tell me if the vtec Head Cover/Cam Seal plate bolts Torque Specs differ from the LS head cover/cam seal plate torque specs. i was reading a post on team-integra.net with diagrams and it noted that the non vtec torque specs will be different. http://www.team-integra.net/se...D=613
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Th3savinday »</TD></TR><TR><TD CLASS="quote">it should be fine just turning the nut into it seems pretty tight. thats what i did with mine and it is completely fine</TD></TR></TABLE>
wow
wow
i just replaced mine..both cam seal and valve cover
here's a step by step for you!!
http://www.team-integra.net/se...D=576
here's a step by step for you!!http://www.team-integra.net/se...D=576
thanks but i had referenced that article in my original post..
it was the line in that post that said...
If you have you a non-vtec engine. The torque settings will be a little different…
i have an LS and wanted to know what the difference is?
it is a small bolt so it will be something around 15 ft/lb, and hand tight is fine, coz if u cant put out 20 ft/lb by using one hand, u need to work out more
stocker2shocker91
Mar 16, 2010 09:43 AM
