new and have transmission fluid question
im quite confused, a few menchanics told me my car doesnt use transmission fluid, so wut do i have the haynes manual said "transaxle fluid",,, what is this and how is it different from transmission fluid, also can i use honda mtf for this?
Ummmm... What kind of car? '72 Pinto??
Newer Hondas with manual trannys take Honda MTF.
Older (up to about '96?) take 10w-30 engine oil in the manual tranny. Honda MTF is good in those trannys.
Even older (I don't know - late '70s?) it's possible the manual tranny needs API GL4 or GL5 gear oil. Honda MTF is NOT good here.
You really need to find out from the owner's manual.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostmee »</TD></TR><TR><TD CLASS="quote">sorry i didnt specifiy, its a 92civic 5spd 4dr lx </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">Older (up to about '96?) take 10w-30 engine oil in the manual tranny. Honda MTF is good in those trannys.</TD></TR></TABLE>
Some people say they've had good results with GM Synchromesh, but I haven't tried that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostmee »</TD></TR><TR><TD CLASS="quote">but does it matter if i use honda mtf in the manual transaxle, whats the difference between the transaxle and the acrtual transmission?</TD></TR></TABLE>
Same thing really.
Keep it Honda MTF, you won't have to worry about a thing
Same thing really.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostmee »</TD></TR><TR><TD CLASS="quote">... whats the difference between the transaxle and the acrtual transmission?</TD></TR></TABLE>Just picky details in terminology. You have a transaxle, but most people still call it a transmission.
On a rearwheel drive car, the differential is separate from the transmission. Transaxle is just a term someone invented for a combined transmission with differential inside the same case.
thanks for clearing that up guys, my shifting is kind of rough sometimes after the car has been running for over 20 min, could that be the cause of needed tranny fluid changed?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostmee »</TD></TR><TR><TD CLASS="quote">thanks for clearing that up guys, my shifting is kind of rough sometimes after the car has been running for over 20 min, could that be the cause of needed tranny fluid changed?</TD></TR></TABLE>
It's possible. Drain it and refill with Honda MTF (manual transmission fluid), and see if it improves.
