b18a1 swap use what hareness help
I have a dx dual point civic and I an planning on doing a b18 swap and I need to know if I use the wiring in the car and modify that one or use the one that come off with the enegine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prcivic91 »</TD></TR><TR><TD CLASS="quote">I have a dx dual point civic and I an planning on doing a b18 swap and I need to know if I use the wiring in the car and modify that one or use the one that come off with the enegine</TD></TR></TABLE>
Much easier to modify the existing wiring to run MPFI in my opinion.
Agreed. You will need the B18a1 harness though for th extra parts {Injector clips and such. DPFI to MPFI = lots of fun. Always use the stock vehicle harness then modify that.
thanks along with mofitying the stock harness I have to pinout the harness to the ecu correct? I also need the resistor box to the injectors? does anybody have a write up on pinning out the ecu
Modified by prcivic91 at 9:08 AM 4/12/2007
Your search for MPFI conversion returned 69 results
Start here: https://honda-tech.com/zerothread?id=724671
Or in the FAQ (that's why it's there!) : https://honda-tech.com/zerothread?id=639552
91H4hatch
Sep 1, 2006 12:24 PM
ivanson
Nov 5, 2005 06:00 PM
