How to clean oxidization off windows?
Old Apr 8, 2007 | 10:17 PM
deeksmooth's Avatar
Default How to clean oxidization off windows?
OK i JUST got a brand new 07 STI, and washed it for the first time tonight... i get to my windows and notice water spots that won't go away. is there a cleaning agent that will help? cause windex didn't do shiz.
Old Apr 8, 2007 | 10:21 PM
Cory Matthews's Avatar
Default Re: How to clean oxidization off windows? (deeksmooth)
i used to use a razor blade when i had my civic. iono if you want to try though on a o7 sti.
Old Apr 8, 2007 | 10:26 PM
deeksmooth's Avatar
Default Re: How to clean oxidization off windows? (Cory Matthews)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cory Matthews &raquo;</TD></TR><TR><TD CLASS="quote">i used to use a razor blade when i had my civic. iono if you want to try though on a o7 sti.</TD></TR></TABLE>
yeah i'm going to have to pass on that one... any chemical agents, like along the lines of windex?
Old Apr 8, 2007 | 10:40 PM
1DA2NV's Avatar
the way you should do this is go to home depot buy one of those plastic scouring pads ppl use for dishes, then park your car in the shade to make sure the windows are cool, then soak them in windex, any kind will do, after a little while you will see the windex working but you need to help so take the pad and in a one way circular motion clean the window off, as you do this use paper towels to clean the area you just did, you'll see this works real well, its what i have done for years and my windows look like they aren't even there
Old Apr 8, 2007 | 10:41 PM
deeksmooth's Avatar
Default Re: (1DA2NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1DA2NV &raquo;</TD></TR><TR><TD CLASS="quote">the way you should do this is go to home depot buy one of those plastic scouring pads ppl use for dishes, then park your car in the shade to make sure the windows are cool, then soak them in windex, any kind will do, after a little while you will see the windex working but you need to help so take the pad and in a one way circular motion clean the window off, as you do this use paper towels to clean the area you just did, you'll see this works real well, its what i have done for years and my windows look like they aren't even there</TD></TR></TABLE>
this doesn't scratch or leave swirl marks? and can u link an image to the pad on home depot's site or something? it may be generic but i don't wanna end up with a f'n SOS pad destroying my windows.
Old Apr 8, 2007 | 11:57 PM
inkedup's Avatar
Default Re: (deeksmooth)
You could try soaking a rag in vinegar and laying it across the glass for a few minutes allowing it to loosen up the water spots, then wash it off.
Or
http://www.detailcity.com/dp-h....html
Old Apr 9, 2007 | 07:48 AM
deeksmooth's Avatar
Default Re: (inkedup)
kick ***, ty for the reply and the glass restorer, i'm going to check that stuff out.
EDIT: just ordered the DP glass restorer stuff, i'll let you know how it works out.
Modified by deeksmooth at 8:59 AM 4/9/2007
MSchu
Detailing
13
Nov 11, 2008 04:27 PM
AMG
Oct 5, 2005 01:15 AM
kX
Jul 9, 2005 02:51 PM
DVS Luder
Jan 9, 2005 06:44 AM
gribbs
26
Apr 19, 2003 11:40 PM
