VALVE COVER GROUND **INFO NEEDED*
Old Apr 8, 2007 | 07:28 PM
vtac sonn's Avatar
Default VALVE COVER GROUND **INFO NEEDED*
is the valve cover ground completely necessary or will the car not run without it??
yes i know its a complete noob question..
so what
Old Apr 8, 2007 | 07:37 PM
immrtaltchnq's Avatar
Default Re: VALVE COVER GROUND **INFO NEEDED* (vtac sonn)
it will run without it, its good to have
but really barely affects anything
why dont you have one?
Old Apr 8, 2007 | 07:39 PM
leeminho86's Avatar
Default Re: VALVE COVER GROUND **INFO NEEDED* (immrtaltchnq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by immrtaltchnq &raquo;</TD></TR><TR><TD CLASS="quote">it will run without it, its good to have
why dont you have one?</TD></TR></TABLE>
Just curious if I understood the question correctly, the ground that attaches to the valve cover? My car wouldn't start without it attached...are we thinking of the same ground?
Old Apr 8, 2007 | 07:43 PM
Default Re: VALVE COVER GROUND **INFO NEEDED* (leeminho86)
your car sucks then
mine didnt have one at first
and it ran fine
not having one ground will nto affect your car
Old Apr 8, 2007 | 07:44 PM
leeminho86's Avatar
lol, just curious, ya my car sucks
Old Apr 8, 2007 | 07:47 PM
i didnt mewan your car sucks really i was kidding
but the only reason you might have probelsm is if your missing like 90 percent of the grounds in the engine bay
which would be ahrd to do
Old Apr 9, 2007 | 07:13 AM
vtac sonn's Avatar
i am shaving my engine bay and did the radiator support first and accidently welded the hole for it shut
yes im dumb
thanks for the info
Old Apr 10, 2007 | 07:29 PM
myfirstdc2's Avatar
nah u don't need it. it will work fine without it. just reground some wires elsewhere like on the block.
Old Apr 11, 2007 | 07:28 PM
mcgee*'s Avatar
Cigarette Squad
Default Re: VALVE COVER GROUND **INFO NEEDED* (myfirstdc2)
mine didnt start with that ground either...hmmm
Old Apr 11, 2007 | 07:38 PM
myfirstdc2's Avatar
Default Re: VALVE COVER GROUND **INFO NEEDED* (McGeeTM)
then u might want to check all your grounds. u dont have to have that specific ground on the valvecover for your car to start. if u have a ground on the block for instance. then the head is automactically grounded, because its mated to the block. its pretty basic electrical
Old Apr 11, 2007 | 07:41 PM
aaronISthrowed's Avatar
I wouldn't run without it, i'm sure its there for a reason.
Old Apr 11, 2007 | 07:47 PM
vtac sonn's Avatar
thats a sweet diagram
Old Apr 11, 2007 | 08:50 PM
b20acura's Avatar
Default Re: (vtac sonn)
i have no clue
Old Apr 11, 2007 | 09:33 PM
italionstallion888's Avatar
Default Re: VALVE COVER GROUND **INFO NEEDED* (aaronISthrowed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronISthrowed &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't run without it, i'm sure its there for a reason.
my girlfriend changed her valve cover from the obd1 ls to the obd2, had the ground there and the car wouldn't start, couldn't even pop the clutch, moved the ground and it fired right up.
Old Apr 11, 2007 | 10:11 PM
slowrx's Avatar
I moved mine to make it a little cleaner, car runs just as good with it grounded on the valve cover.
Old May 4, 2007 | 04:55 AM
nightkid1's Avatar
My car wouldnt run with out it but i dont have a ground to the block so i think if maybe u have the block ground then sure it will work but if not then it prolly wont crank
Old May 4, 2007 | 05:27 AM
MatrixShark's Avatar
I love it.
Old May 4, 2007 | 08:10 AM
myfirstdc2's Avatar
that's odd. alot of you are saying that it won't start. all my cars didn't have it there. like i said b4, i regrounded mine elsewhere.
Old May 4, 2007 | 08:25 AM
1uncleanDA's Avatar
Well..Mine does not have one and starts and runs great...Idk
slammeddime
Apr 3, 2013 10:29 AM
ezcape
May 10, 2011 10:52 PM
civic89si666
Aug 29, 2006 07:51 PM
EKen9
Jun 23, 2002 05:34 AM
