Need advice on my GSR build! please!
Old Apr 8, 2007 | 07:19 PM
401tuner's Avatar
Default Need advice on my GSR build! please!
ive been searching alot and trying to decide what im going to end up doing with my gsr. I found it somewhat hard to find information when i have specific things i want to do, conserining my own build. I was planning on doing more of an OEM bottom end and spending the money on the head. This car is going to be my daily driver, so im trying to figure out a build that will work good, being my daily. While trying make it some-what of a budget build.
<U>Block:</U>
Stock sleeves
Bore .20 over (81.5mm)
Use my gsr rods (get them cleaned and polished)
Oversized b16 pistons
<U>Head:</U>
Supertech valve train=
- flat faced or dish vales??? (trying to decide between the 2)
- dual valve springs
- retainers
Good port and polish (hot tanked)
Skunk 2 stg 2's or BC spec III's, any other opinions? I cant decide.
Skunk 2 cam gears
IM and TB bored
Also trying to decide on a header at the moment.
Opnions and suggestions would help me out so much. It would be appreaciated guys.
Old Apr 8, 2007 | 07:49 PM
401tuner's Avatar
Default Re: Need advice on my GSR build! please! (401tuner)
bumpp, anyone
Old Apr 8, 2007 | 09:29 PM
all-mtr-teg's Avatar
If you go w/ the BC3 cams, it will make a great dd. I have those in my 97 gsr dd. w/ only the supertech dual v.s. and stock retainers. Stock rods and crank, usdm p73 pistons. In my weekend car 98 gsr, i have the blox type b cams, (similar to skunk 2 cams) with the supertech valve train, stock retainers. Stock rods with arp rod bolts and jdm p73 pistons. Both redline is set to 9K rpm, but my dd rarely sees above 8400 rpm
Old Apr 9, 2007 | 08:07 AM
401tuner's Avatar
Default Re: Need advice on my GSR build! please! (all-mtr-teg)
yea trying to decide things like this is a pain in the ***, anyone else have any suggestions, or comments about the build i want to do?
Old Apr 9, 2007 | 10:38 AM
401tuner's Avatar
ttt?
Old Apr 9, 2007 | 05:18 PM
HondaCivicSiR1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 401tuner &raquo;</TD></TR><TR><TD CLASS="quote">ive been searching alot and trying to decide what im going to end up doing with my gsr. I found it somewhat hard to find information when i have specific things i want to do, conserining my own build. I was planning on doing more of an OEM bottom end and spending the money on the head. This car is going to be my daily driver, so im trying to figure out a build that will work good, being my daily. While trying make it some-what of a budget build.
<U>Block:</U>
Stock sleeves
<U>Head:</U>
- retainers
Skunk 2 cam gears
IM and TB bored
</TD></TR></TABLE>i think with rmf or the other one's similar to that would be a good choice,but if money is a issue i would a jdm 4-1 header. everything else sounds like it would be a fun d/d good luck on your build
Old Apr 9, 2007 | 09:30 PM
dinko's Avatar
Default Re: Need advice on my GSR build! please! (HondaCivicSiR1)
don't forget ARP bolts!
for a daily driver i would look to a header that has incredible ground clearance. a lot of jdm 4-1 is pretty much the same. i had one and it hung really low. i was really careful not to scrape it, but i only drove the car 3500 miles.
if you're not in a hurry and got the money, i would look to top doggs...rmf/smsp for ground clearance / power.
Old Apr 10, 2007 | 04:48 PM
401tuner's Avatar
Default Re: Need advice on my GSR build! please! (dinko)
yea i was thiking about getting the rmf narrow, just gotta find one for sale first, or have one made. Just hopeing its not redicilous amount of money tho
xotic_crx
17
Oct 28, 2014 04:00 AM
GSR615
67
Mar 16, 2009 02:51 PM
401tuner
Jan 30, 2008 06:22 PM
401tuner
Apr 10, 2007 04:49 PM
eg6rider
May 11, 2006 03:16 PM
