FS/TW: JDM DC2 Championship white ::: SOCAL 626 :::
****SOLD***
This car for sale is a mix of everything really....
95 RS Body + 95 GSR Motor. A lot of hard to come-by parts on here. Call it a type-r wannabe if you want
Engine:
-Skunk 2 Intake Manifold
-Type R Muffler
-Cold air intake
Exterior:
-OEM JDM Front end with HID-headlights
-OEM Lip Kit
-OEM Type R Wing
-Shaved Side Moldings
Suspension:
-Function Type 2 Coilovers (less than 1000 miles on them)
-Type R strut bar
-ASR rear subframe brace
-Zspeed 23mm swaybar, poly bushings
-Omni Power lower control arms
-Rear camber correction
-Type R 5 lug conversion
-2001 Gunmetal Type R wheels
Interior:
-Type R front seats
-JDM Type R rear seats
-Type R floormats. I have both the jdm and usdm ones that come with the car.
-JDM Type R cluster
-JDM Type R SRS steering wheel
-all the Type R CF intereior peices
-Type R Shift ****
-Type R door sills
-Clifford Inteliguard 800 alarm
-JDM Type R Key!
-2 12" subs with 300 watt amp
There might be more to list. New OEM clutch installed 7 months ago, new tires with about 300 miles. Oil changed regularly, cam seal is leaking a little, but thats easy to fix. Motor has about 120k miles, compression still good. Title is salvage due to theft recovery. The car never really beat on, no racing, head has never been taken off the block, all stock inside.
I need to get rid of this car so I can upgrade to a bigger car. Serious inquires only please.
Email kmk0228@gmail.com
$8000 ***OBO*** for a good clean daily driver.
Modified by intekragsr at 2:41 PM 4/29/2007
Engine:
-Type R Muffler
-Cold air intake
Exterior:
-OEM Lip Kit
-OEM Type R Wing
Suspension:
-Type R strut bar
Interior:
-Type R front seats
-JDM Type R cluster
-Type R Shift ****
-Type R door sills
-JDM Type R Key!
