Gsr and Ls exhaust the same???
Old Apr 8, 2007 | 06:22 PM
EvilJunkee's Avatar
Default Gsr and Ls exhaust the same???
Anyone know if there is any difference between an Ls and a Gsr exhaust? i recently bought a Apexi Noir Gsr exhaust for my Ls and it happens to be about 4 inches longer and hangers are in a different location, anybody know???
Old Apr 8, 2007 | 07:00 PM
Padawan's Avatar
Darth ModerVader
Default Re: Gsr and Ls exhaust the same??? (EvilJunkee)
As you've discovered, the '94-'99 GS-R exhaust is approximately 4"-4.5" longer than the LS exhaust.
Old Apr 9, 2007 | 08:58 AM
kinick313's Avatar
yep, sounds like you answered your own question
Old Apr 9, 2007 | 06:01 PM
EvilJunkee's Avatar
ok but does the chassis have the same size groove for the exhaust to sit in ?
Old Apr 9, 2007 | 06:19 PM
Padawan's Avatar
Darth ModerVader
Default Re: (EvilJunkee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvilJunkee &raquo;</TD></TR><TR><TD CLASS="quote">ok but does the chassis have the same size groove for the exhaust to sit in ?</TD></TR></TABLE>
I don't really know what you mean by "groove", but the chassis is essentially identical between the two models.
Old Apr 9, 2007 | 07:40 PM
EvilJunkee's Avatar
Default Re: (Padawan)
identical, ok thats all i needed to know... thanx
Old Apr 9, 2007 | 07:44 PM
princefredo's Avatar
someone correct me if im wrong. but its because the gsr exhaust manifold is shorter then the ls. thats why the exhaust you bought is longer . all you have to do is shorten the b-pipe and it will bolt right up.
Old Apr 10, 2007 | 06:19 PM
EvilJunkee's Avatar
Default Re: (princefredo)
actually the Gsr exhaust that i got is longer than the stock Ls exhaust... but you know what i think, i think its because i got one for a sedan... its hard to say cuz nowhere on the box or the installation sheet does it say anything about sedan or coupe, it kinda sux! i gotta contact Apexi to see whats up...
Old Apr 10, 2007 | 08:59 PM
liftedresearchgroup's Avatar
na son
GSR is better
Old Apr 10, 2007 | 11:08 PM
TastyDragon's Avatar
Default Re: Gsr and Ls exhaust the same??? (liftedresearchgroup)
correct me if im wrong but isnt the 94-99 gsr exhaust manifold tha same length as the ls? its just tha 00-01 gsr exhaust manifold is shorter so the b-pipe would be longer.
a side question, but can you swap a ls or typeR header onto a 00-01 gsr head?
Old Apr 11, 2007 | 12:52 AM
YellowPhoenix095's Avatar
^ All B-series exhaust manifolds have the same bolt pattern = you can put whatever B-series header you want on a B-series head. Your just going to have to accomdate your exhaust to fit your header. Or a better alternative is to get a test pipe made.
Old Apr 11, 2007 | 04:29 AM
Padawan's Avatar
Darth ModerVader
Default Re: Gsr and Ls exhaust the same??? (TastyDragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TastyDragon &raquo;</TD></TR><TR><TD CLASS="quote">correct me if im wrong but isnt the 94-99 gsr exhaust manifold tha same length as the ls? its just tha 00-01 gsr exhaust manifold is shorter so the b-pipe would be longer.
a side question, but can you swap a ls or typeR header onto a 00-01 gsr head?</TD></TR></TABLE>
The '94-'99 GS-R manifold is shorter than the LS, hence the reason that the '94-'99 GS-R needs a longer exhaust B-pipe. The '00-'01 GS-R, the LS, and the ITR all have the same length manifolds and exhausts, and they're completely interchangeable.
Any of them will bolt to any B-series head, however.
Old Apr 11, 2007 | 01:18 PM
Default Re: Gsr and Ls exhaust the same??? (Padawan)
thanks for clearing this up
It's*BOLO!!
Mar 27, 2011 01:10 PM
lPat
Oct 5, 2007 02:04 PM
Honda_Fanatic
Mar 6, 2007 09:10 PM
dabrown
Apr 19, 2004 07:23 AM
Adampops
May 13, 2003 06:27 PM
