tire size
Old Apr 8, 2007 | 03:17 PM
betta285's Avatar
Default tire size
I am going to get these wheels
http://www.sportmaxwheel.com/sportmax_941.shtml
15's but i'm unsure of what size tires to get. I would like have an aspect ratio of 50, but i'm not sure what size width to go. what would fit best/look best. Are 195/50/15 too small?
Old Apr 9, 2007 | 03:56 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: tire size (betta285)
yes, a 195/50/15 would be too small in both overall diameter (compared to stock tire size) and width (for that rim).
You are going to want something like a 215/55/15 for that rim. Depending on the offset you may be ok with a 225/50/15 but the overall diameter on that tire is on the smaller side but your speedo should be off much if you do go with it.
If you want a smaller side wall, you are going to have to go with a larger diameter rim.
Also, just because a tire has a 50 series side wall doesn't mean the side wall is smaller or different than say a tire with a 60 series side wall. Example... a 195/60/15 and a 235/50/15 have pretty much the same side wall size. It's just a ratio of the width of the tire.
Old Apr 9, 2007 | 08:20 AM
thetomshow's Avatar
what is your car ??
Old Apr 9, 2007 | 08:24 AM
H-T Order of Merit
Default Re: tire size (thetomshow)
I'm going to guess the 97 Accord thats in his sig?
Old Apr 9, 2007 | 08:28 AM
thetomshow's Avatar
Default Re: tire size (TouringAccord)
sorry lol your right .. for a 4th gen a ******* big drop on 15 is ice but on a 97 acc .. go for 17 inch wheel please
bmwracer316
Aug 15, 2007 08:32 PM
jdmhatch3
Aug 11, 2005 04:50 AM
drewlee
Apr 8, 2003 08:28 AM
whagkangmakulet
Aug 22, 2002 05:39 PM
