Please!!!! I need help, my car won't start
Old May 27, 2002 | 09:21 AM
FOrSfEd's Avatar
Default Please!!!! I need help, my car won't start
It seems like **** just keeps getting worse. But anyway my car will not start. It would start fine before crank right up, but know I can't even get it to turn over. I checked all the wiring, all the fuses inside and outside the car everything looks fine. The only thing I did was take off my check valves for my turbo and put them back on. WTF anybody got any suggestions. Battery seems to be good I'm not getting any battery light and all of my accersories work fine, my car just won't turn over. It seems like if you have a security system and you have starter kill on the alarm only I don't have any type of alarm or anything like that. Somebody help me please.
Lee
Old May 27, 2002 | 09:26 AM
EightOhOne's Avatar
Default Re: Please!!!! I need help, my car won't start (Rex2nv)
double check your grounds in your engine. mine did something similar to that, with accessories working and all. It turned out to be the screw thst holds the wires onto the terminal clamp had some corrosion and wasnt allowing it to ground. I unscrewed it a little bit, and now it works fine
gwegcivic
Audio / Security / Video
24
Mar 25, 2013 02:25 PM
carlosp38
Sep 28, 2008 09:49 PM
EJC413
Apr 26, 2006 01:22 PM
shipsaeki
Mar 4, 2003 06:14 PM
