Gutting my DA
Old Apr 8, 2007 | 01:51 PM
jdmkid8383's Avatar
Default Gutting my DA
91 DA iM gutting her to be light as posssible what can I take out. Soo far I took out the cruise control, power doors, power mirriors, abs computer, seat belts for 4 point harness, heater, ac unit, and power mirriors but theres still more wires help yall I want the inside to have no carpet and look clean!!!!!
Old Apr 8, 2007 | 02:35 PM
davidluko's Avatar
Your car's not gonna look 'clean' with that jumble of wires hanging out where the dash used to be. You can scrape off the sound deadening by freezing it with dry ice and then using a chisel, hammer, and goo-gone. That'll save weight and make it look better without the carpet, but only if you paint over where you removed the sound deadening to make it match the rest of the car. BTW, if you're going as far as taking the dash out, you might as well remove all the seats but the driver seat and take off the door panels.
Old Apr 8, 2007 | 02:41 PM
jdmkid8383's Avatar
Default Re: (Hatch_R)
these are not up dated pics I took out the dash and will be painting the inside and out of the car Khaki a friend of mine told me I can heat up the tar stuff that keeps the sound out than take a scraper and it will come right off. Besides that I have a gang of wires on the drivers side what can I take out? all I want are all the lights to work inside and out, gas gauge, temp, rpm, and mph, as well as the motor how can I organize the wires to make it look simple
Old Apr 8, 2007 | 02:47 PM
rare_db2's Avatar
Front and rear bumper supports are 40 plus lbs.. You relize you will wanna put it all back one day, you always do trust me.
Old Apr 8, 2007 | 02:51 PM
jdmkid8383's Avatar
Default Re: (rare_db2)
I need the bumper supports in the front and rear for safty butthe inside is in the works of a jungle gym cage lol but as far as the wires go talk to me
Old Apr 8, 2007 | 03:17 PM
mike5809's Avatar
Default Re: (jdmkid8383)
jdm bumper supports weigh alot less don't they?
Old Apr 8, 2007 | 03:20 PM
jdmkid8383's Avatar
Default Re: (mike5809)
I believe so
Old Apr 8, 2007 | 03:27 PM
mike5809's Avatar
yeah I think they are 3lbs or something crazy like that.
Other than that just normal stuff like:
-Gutting Interior
-Remove P/S
-Remove A/C
-Get some carbon fiber stuff
-Fiberglass fenders/hood
-Light weight wheels
-Lexon windows
-CF hatch
-JDM Bumper Supports
-Take sunroof out if you have one and Cap it
It all depends what all you are trying to do, if you are not planning on trying it on the street ever, you can start to cut some of the body off and welding thiner sheet metel peices on.
Old Apr 8, 2007 | 04:25 PM
jdmkid8383's Avatar
good stuff well Im going to keep her as a daily driver but I want it to look mean I think the lexan windows on the rear and side would look dope but as far as the wires go what can I trash..
Old Apr 8, 2007 | 04:32 PM
I AM WEASEL's Avatar
You can also take out the back seats as well as the speakers and your whole sound system. If you're going for the lightest possible setup you should just start with a tube chasis fiberglass body pannels and just the necessities.
Old Apr 8, 2007 | 04:51 PM
jdmkid8383's Avatar
Default Re: Gutting my DA (jdmkid8383)
well its going to be a street car on the real I want bumps 10'' sub in the back
carbon fiber hood, trunk, fenders
carbon fiber racing seat non-recline
b18b non-v turbo 6psi daily and 12psi on weekends
drilled holes in rear bumper
no abs
no carpet
will have removable rear seats and body panels incase some peeps wanna roll
no heater
no p/s
no cruise control
no ac unit
eg radiator
no inside roof panel
roll cage
0 off set sport max wheels 3 inch lip
Old Apr 8, 2007 | 06:37 PM
diep316's Avatar
Removing all these stuff wouldnt be safe.
Old Apr 8, 2007 | 06:40 PM
CleanLikeJdm's Avatar
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmkid8383 &raquo;</TD></TR><TR><TD CLASS="quote">well its going to be a street car on the real I want bumps 10'' sub in the back</TD></TR></TABLE>
With taking out as much weight as possible, you do not Add comforts.
If this Really is your dd, I wouldn't do that much to it.
Old Apr 8, 2007 | 06:47 PM
ritalin.v2's Avatar
Default Re: Gutting my DA (CleanLikeJdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">With taking out as much weight as possible, you do not Add comforts.
If this Really is your dd, I wouldn't do that much to it.</TD></TR></TABLE>
Yeah I would've stopped a long time ago. My da is my daily and the only things I removed were the a/c in the bay, removed the p/s belt and removed my rear seat. Still have the spare and jack in there. Drive it everyday.
Old Apr 8, 2007 | 06:58 PM
mike5809's Avatar
Default Re: Gutting my DA (diep316)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diep316 &raquo;</TD></TR><TR><TD CLASS="quote">Removing all these stuff wouldnt be safe. </TD></TR></TABLE>
How would removing this stuff not be safe?
Removing some of this stuff sure would possibly make it unsafe, but most of it would not really take away from the safety.
-getting rid of ac, ps, carpet, heater, cruise control, roof panel, rear bumper defuser, etc I don't see how would make it unsafe really for normal daily driving, uncomfortable yes, unsafe probally not.
But by doing this, it is kind of pointless if you are putting a system in with a subwoofer?
Old Apr 9, 2007 | 12:38 AM
jdmkid8383's Avatar
Default Re: Gutting my DA (ritalin.v2)
well the sub in box weighs 4lbs the amp is 1lbs than I got highs and mids just to listen to when Im hype and feelin good
Old Apr 9, 2007 | 04:33 AM
tweekerz's Avatar
I believe you should only gut the car if you plan on keeping it that way. Its just not worth the hassel to put it back together.
Old Apr 11, 2007 | 01:47 AM
jdmkid8383's Avatar
Default Re: Gutting my DA (tweekerz)
whats up with peeps on honda-tech seems like yall arnt willing to go the extra mile like myself rhd conversion is different and not that difficult to do if you like cars and motivated to drive on the right lol I dream about it everyday lol. Alot of yall are like ohh dont do it its not worth it well to me it is and when my **** is done everyones going to jock hahaa
Old Apr 11, 2007 | 02:37 PM
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmkid8383 &raquo;</TD></TR><TR><TD CLASS="quote">like myself rhd conversion is different and not that difficult to do if you like cars and motivated to drive on the right lol I dream about it everyday lol. </TD></TR></TABLE>
um, sure? I guess it would be fun driving on the right side, if I lived in japan..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmkid8383 &raquo;</TD></TR><TR><TD CLASS="quote"> Alot of yall are like ohh dont do it its not worth it well to me it is and when my **** is done everyones going to jock hahaa</TD></TR></TABLE>
Whats cool about a stripped integra?
Old Apr 11, 2007 | 02:43 PM
Backk InTheDA's Avatar
I hate everything
Whats cool about a stripped integra?</TD></TR></TABLE>
It's his car man, leave him be.
Old Apr 11, 2007 | 04:29 PM
Hype-R Stalker
Default Re: Gutting my DA (Backk InTheDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Backk InTheDA &raquo;</TD></TR><TR><TD CLASS="quote">
It's his car man, leave him be.</TD></TR></TABLE>
Oh, I'm sorry, I forgot opinions Mattered ..
Also, don't try to give ME **** when I put offence to the comment that a Stripped teg would be cool,
cause guess what, it's a STOCK integra with a stripped interior.
Wow, why doesn't he just let someone steal it,
then he would just need to add an engine most likely.
Btw
https://honda-tech.com/zerothread?id=1888682
Stfu
Old Apr 11, 2007 | 04:38 PM
I hate everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">Stfu </TD></TR></TABLE>
Oh noes, attempted internet ownage:
http://en.wikipedia.org/wiki/Fail
Old Apr 11, 2007 | 04:46 PM
JDM-EJ1's Avatar
Btw
Wow, a number of things are wrong with your post. I'll start from the top, why are you capitilizing random words such as 'mattered' and 'stripped', while refusing to capitilize words such as 'Integra'?
We understand that you're upset because you don't have the skill and knowledge to do a project like this. Please take your anger out by slamming your face into a brick wall. Thanks.
Old Apr 11, 2007 | 05:47 PM
Hype-R Stalker
Default Re: Gutting my DA (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Backk InTheDA &raquo;</TD></TR><TR><TD CLASS="quote">Oh noes, attempted internet ownage:</TD></TR></TABLE>
I was just pointing out that you're a Tool, simple as that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
We understand that you're upset because you don't have the skill and knowledge to do a project like this. Please take your anger out by slamming your face into a brick wall. Thanks.</TD></TR></TABLE>
I'll capitalize whatever the Fu<u></u>ck I want,
and which "capitalize" is a word you can't even spell.
And how the hell is removing interior a "project"??
I seriously had to think about it when you said project,
cause in no way is taking **** off your car a project..
But I guess you must me among the few that think adding seat covers is a mod,
or maybe you consider Wal-Mart the main choice for your tuner supply.
I speak "****" about stripping the interior from personal experience,
the only time it's cool is when you also think street racing is cool,
or maybe you think that taking the interior out will make you run 12s.
So with that behind me, and being done with this thread, diaf
jdmkid8383's Avatar
hahaaa
