Shifting at 10,000 rpm?
Old May 27, 2002 | 09:09 AM
jond's Avatar
Default Shifting at 10,000 rpm?
In the videos DB8GSR posted, they're shifting at 9,500 and 10,000 rpm!
Whats the deal with that?
Old May 27, 2002 | 09:14 AM
DutchITR1689's Avatar
Default Re: Shifting at 10,000 rpm? (jond)
More power! If it still generates torque at that rpm.....
Old May 27, 2002 | 09:17 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Shifting at 10,000 rpm? (DutchITR1689)
If it's the video I think you're talking about where it's just two videos of the cluster (one with music and one without), then it's not "real." His tach was not calibrated.
If you listen to the engine sound, it doesn't sound anywhere near that high. Plus his idle was about 4-5Krpm.
Anywho, it certainly is possible to have shift points that high. It all depends on the power you're making and the reinforcements in the head. You definitely need some hardcore valve springs/retainers. You also have to make sure that the cams you are working with even make power that high up.
Say you chip and spring a head with stock cams to 10Krpm. The power/torque will drop at around 7000rpm or near that. There's no point to go much higher, you'll actually slow down.
Old May 27, 2002 | 09:22 AM
jond's Avatar
Default Re: Shifting at 10,000 rpm? (shamoo)
This is one of them:
https://honda-tech.com/zerothread?id=194721
Old May 27, 2002 | 09:24 AM
shamoo's Avatar
Whoops, my bad then.
Nope, that's certainly real.
Old May 27, 2002 | 10:15 AM
GokuSSJ4's Avatar
Default Re: Shifting at 10,000 rpm? (C5_ALLMOTOR)
higher CR and better valvetrain
Old May 27, 2002 | 07:20 PM
TypeR_853's Avatar
hahaha very well tuned Rs by the crazy men of japan that actually know what they're doing
these engines can handle those shift ranges if they are tuned correctly and have the right internals...
Old May 27, 2002 | 07:48 PM
rurkster's Avatar
I think my tac would be bouncing around far b4 i got there, as for your question, yeah i'd say it aint real.
Old May 27, 2002 | 07:52 PM
TypeR 599's Avatar
Default Re: Shifting at 10,000 rpm? (rurkster)
they might have changed the rev limiter to 10k
CheezeFrog's Avatar
FWIW, I believe st00pid was shifting at 10.5k on a stock GS-R top end. He may have had springs/retainers, but I'm almost positive the top end was completely stock. I'll check on this though. At any rate, 10k+ is definately possible.
Old May 27, 2002 | 08:01 PM
Floyd's Avatar
Default Re: Shifting at 10,000 rpm? (CheezeFrog)
I don't think they were getting to 10, but damn close.
Old May 27, 2002 | 08:08 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Shifting at 10,000 rpm? (Floyd)
9,600 looks like my guess. not 10k, but close.
Old May 27, 2002 | 08:11 PM
ppihctyper's Avatar
FYI I have seen a few B16's that were taken to 12,000+ stateside. Of course they were drag cars intended to last in ideal times for about an 11 sec stint. But, it is possible to make power that high, in fact remember only 120 ft torque at 10,500 is still 240 hp! So yeah the law of diminishing returns comes into play, but gearing and rotational inertia do have a lot going for them.
Old May 27, 2002 | 09:04 PM
B2FiNiTY's Avatar
Default Re: Shifting at 10,000 rpm? (ppihctyper)
I redline at 6.3K RPM
Old May 27, 2002 | 09:52 PM
VaporTrail's Avatar
New User
a good friend of mine with a built b18c, stock cams but springs and retainers, revs to 11.5k or so in his T66 turbo drag civic generating 670whp. Not relavent, but interesting none the less.
Old May 27, 2002 | 10:24 PM
GokuSSJ4's Avatar
Default Re: Shifting at 10,000 rpm? (VaporTrail)
seen up to 10, 800rpms . but also sometimes the oem cluster are off do'h.
B_Swapped93
17
Apr 4, 2013 12:51 PM
Mo_Spec
Jun 8, 2011 09:40 PM
RacinMasonC
Nov 7, 2008 12:31 AM
hott-nix
Sep 20, 2004 11:12 PM
RAB
Sep 12, 2002 09:37 AM
