Another brake question....
Old May 27, 2002 | 09:09 AM
B_CRUZ!'s Avatar
Default Another brake question....
***i did a search***
1) I Heard it is bad to put SS brake lines in the front if you have drums in the back... T or F? I heard it has something to do with to much fluid pressure thats going to be sent to the back...
2) If i upgrade to Integra brakes in the front, is it necessary to upgrade the MC/booster too? and if i don't will it be unsafe?
sorry for the newbie like questions... i am clueless when it comes to brakes...
TIA Honda-Tech!
Old May 27, 2002 | 10:01 AM
tonyxcom's Avatar
Default Re: Another brake question.... (B_Cruz)
1. completely false
2. no you dont NEED to, and it wont be unsafe.
Old May 27, 2002 | 10:04 AM
GokuSSJ4's Avatar
Default Re: Another brake question.... (tonyxcom)
2) it mainly helps went you have rear disk .
Old May 27, 2002 | 10:07 AM
B_CRUZ!'s Avatar
thaks for the responces... i am on a budget and since i finally got the speed part down... i need something to slow me down fast too. will it make a big difference if i just upgrade the front from the small CX brakes i have on there now?
Old May 27, 2002 | 10:21 AM
tonyxcom's Avatar
Default Re: Another brake question.... (VTEC CX)
it will make a difference. But you wont stop any faster. You will just be able to handle the stops from higher speeds with less fade.
you could get away with your stock brakes assuming you had clean rotors and good pads.
but gsr/si front brakes are a worthy upgrade.
Old May 27, 2002 | 10:42 AM
B_CRUZ!'s Avatar
and if i get SS lines, which application do i get? 94+integra or 92+up civic?
TIA
rexfiend1877
Jan 16, 2008 09:16 PM
pineapplemike
Nov 23, 2005 07:25 PM
youngwon22
34
May 5, 2004 02:57 PM
SiR HatchAlot
21
Nov 28, 2003 05:53 PM
dnt94civic
Jun 7, 2002 05:04 AM
