all-motor build died on the dyno...
The tuner did 2 practise runs on the dyno..make sure everything sounds ok at high RPMs. We didnt hear any knocking or any unusual noise. So he started tuning on the 3rd run..which came out to 162WHP..TQ I dont know..he said it should have been a little higher. so he did another run and at 7000. heard a little knock and my car stoped.
We pulled off my valve cover to see anything unusual in the valve train. and 1 exhaust valve and 1 intake valve were open REALLY WIDE! and smoke coming out of only 1 cylinder(white/grey smoke) So we took out the spark plug(will post pics soon)
The spark plug was all chewed up and bunch of pieces inside my cylinder wall.looks like I broke a valve. and the pieces of the broken valve smacked into the spark plug...
My head as fully built. The only thing that wasnt changed on my head were the valve guides..The master honda tech and the tuner said.the valve guides were bad. apparently they were too tight on the valves. causing them not to go in and out how they are suppose to..And I skipped 2 teeth on my timing belt..the out come possibly 2 broken valves..and not going back to the machine shop that told me my valve guides are okay..
here is my setup if some of you dont know..
Darton Ductile Iron Sleeves bored 84mm
JE pistons 84mm(11.5:1 Compression)
Eagle H-Beam Rods
ACL race main/rods bearings
Head has been ported & polished stage 3(3 angle valve job)
KMS development valves, KMS titanium Retainers, & Dual valve springs
Skunk2 Pro-Series 2+ cams
Skunk2 cam gears
Skunk2 pro series intake manifold
Edelbrock 65mm Throttle body
AEM air intake system
Stock OEM type r ignition system w/ NGK iridium
310cc RC engineering injectors
AEM fuel Rail
AEM fuel pressure regulator & AEM FUEL FILTER
Walbro 342 Fuel Pump
Honda OEM 98 spec Type-R Header straight piped to my exhaust
RS-R Exmag Exhaust
ROTATING ASSEMBLY HAS BEEN FULLY BALANCED
Eagle H-Beam Rods
Skunk2 cam gears
AEM fuel Rail
RS-R Exmag Exhaust
From: Boswanna,street radio,riddin in da regal. PA.LLday
that was my worst night mare eventhough i did all the work and crossed all the Ts and dotted the i's ....i was still worried but so far so good...sorry about that man good luch rebuild its worth it in the end
hopefully...I should be back up and running by July..going to go with the skunk2 valve train..hopefully.. the pieces inside didnt scar my cylinder walls too bad, or damage my head...or even the piston...
my worst nightmare became reality.....I did all the work myself too. They did compliment my build though..said it was the cleanest they have seen.as far as wiring, the motor swap, and the motor build was really clean..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit »</TD></TR><TR><TD CLASS="quote">Sorry to hear that. I hope that bottom end is salvageable. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16nonoy »</TD></TR><TR><TD CLASS="quote">hopefully...I should be back up and running by July..going to go with the skunk2 valve train..hopefully.. the pieces inside didnt scar my cylinder walls too bad, or damage my head...or even the piston...</TD></TR></TABLE>
I hate to say it but if you broke a valve, your head and piston are prob messed up badly. and you prob are going to have to bore your block.
What sound did it make?
post pics of the plug.
good luck.
good luck.
yea hopefully not though..it didnt make that loud of a sound..but it was a knock.and then it stoped running...if my piston aint too messed up.I could prolly use some watcha ma call it cloth.and smooth out the dents and stuff so there wont be hot spots....I will maybe pull the head off next weekend...and see how everything else looks...will post pics..later today...
Just curious how the "master tech" can tell you your guides are too tight when he has not seen them yet. What did you degree the Pro2's in at? 100 IN ctr line and 106 EX ctr line?
Also what is the lift capability of the KMS springs and retainers? Do their seat and open pressures match the Pro cams?
Modified by DonF at 8:26 PM 4/8/2007
If youre going to rebuild this one, take the time and do it right. Im with DonF on the guide comment too. Thats a load of bullshit. At least with the head off, you can hold the valve by the head in wiggle it a bit in the guide to get an idea of the wear, but just looking at it with the valve cover removed? Please.
I didnt build the head..a machine shop guy did it for me...did some computer work for him and he was suppose to return the favor..but yea...wish I was the one that put it together myself....
and take it to another machine shop to get a second opinion on the valve guides..>I was originally iffy on that...
yea..it wasnt my valve train package..it was the OEM valve guides..worn out or no good...
also...have heard anything bad about KMS...but I am changing to Skunk2 since I have it open...
old oem valve guides may get a little loose, the valve job doesnt last as long. but I dont see them having much to do with your failure. do you know the specs on your valve springs?
Don't know much about KMS valvetrain so I will not put blame on them.
However, Pro2's are very big and have a good deal of low lift duration, if you aren't careful you can easily get valve-to-valve contact. If you did not clay the motor, I would be hesitant to run more than +2 on the intake, and always advance the exhaust cam a few degrees for safety margin. Off the shelf JE's aren't known for their deep valve reliefs.
Valve guides rarely fail. With that being said, I would say it was a high probability of either coil bind or v2v,p2v.
Modified by 92TypeR at 10:25 PM 4/10/2007
it your valve guides were to tight then they needed to be honed out, not replaced.
they would only be bad it the valve guides were too loose
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">Don't know much about KMS valvetrain so I will not put blame on them.
However, Pro2's are very big and have a good deal of low lift duration, if you aren't careful you can easily get valve-to-valve contact. If you did not clay the motor, I would be hesitant to run more than +2 on the intake, and always retard the exhaust cam a few degrees for safety margin. Off the shelf JE's aren't known for their deep valve reliefs.
Valve guides rarely fail. With that being said, I would say it was a high probability of either coil bind or v2v,p2v.</TD></TR></TABLE>
i'd blame the valvetrain, unless they marked it up and said it will support a 12.5+MM lift..correct me if i'm wrong..buts only a hand full of valvetrain's that will support the pro2/3's lift..
What Valve Size?
What was the Installed Height and Coil Bind Specs for the Springs?
What were the Opening #'s for the Pro 2 Cams @ .040 or what were your cams gears set at?
How much was your head & block Milled?
What was the Valve to Piston Clearence at the valve margin?
Modified by PURE Tuning at 9:46 PM 4/12/2007
