got code 10 and 41..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luvs2spooge »</TD></TR><TR><TD CLASS="quote">how can i fix these problems?
you should probablly tell us what codes they are so that we can tell you. most of us are too lazy too look up the codes.
</TD></TR></TABLE>you should probablly tell us what codes they are so that we can tell you. most of us are too lazy too look up the codes.
https://honda-tech.com/zerothread/1901557
this will tell you every thing
uh actually, the thread only says what they are
not how to fix them...
Take some brake cleaner and clean your IATs electrical connector, glob on some dielectric grease (aka "bulb grease") onto the connector terminals - see if that fixes it (that would fix #10)
If it does, you should just replace your O2 sensor also
http://www.sparkplugs.com - buy denso first time fit (with connector) or dont bother. Do NOT buy bosch from the parts store. Do NOT waste money and go to the dealer.
That will clear #41
If cleaning the iat doesnt do anything, check the alternator fuse under the dash
(really, it should throw eld too, but eh...worth a look)
That will clear #41
now i have code 9 and code 10
i tried to do the thing to the iat but everything is the same
whats code nice.. says cylinder something...
how do i fix code nine?
whats code nice.. says cylinder something...how do i fix code nine?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luvs2spooge »</TD></TR><TR><TD CLASS="quote">now i have code 9 and code 10
how do i fix code nine?</TD></TR></TABLE>
whats code nice.. says cylinder something...how do i fix code nine?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luvs2spooge »</TD></TR><TR><TD CLASS="quote">anyone?</TD></TR></TABLE>
something is really mess up in your wiring(or during your rewiring stuff, u might short sth out and burn the ecu 0V), dont try to do something u are not good at, take it to pro.
Try a different ecu...i seriously doubt there are that many codes.
Also, check your alternator fuse, under the dash.
You can mess up the o2 wiring, btw - there are 2 black wires but theyre different (not grounds)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">LOL. $5 on Code 8 being next - who wants some of that action? j/k
Is the car stock? Or did you do a lot wiring to it?</TD></TR></TABLE>
the motor is stock except header intake and greddy 2mm headgasket
the iat is a bitch.. i can't take it out any ideas? well i checked and the iat wasnt hooked up hahahah no wonder it was driving weird havent checked what codes are on now..
hahahahha all the codes are gone :
all i did was replace the iat and all the codes went away so weird.. now lets see how my gas mileage changes.
thanks guyz
thanks guyz
