Si MC/Booster or ITR MC/Booster
I have a dilema.
I just did 5 lug swap on my 00 hatch. I'm still using the stock Mc/Booster and Prop valve.
I know tht the best (probably the only) Prop valve that I can use will be from an Si.
Now, the hard question...I need a new MC/Booster combo.
I can get a 00 Si MC/Booster for next to nothing, but it's only 15/16"...I can spend $100 and get an ITR unit which is 1".
Will 1/16" make that much of a difference? Or should I stick with the ITR unit?
tia
tia
well, right now it sucks ***.
One of the brake lines came loose, so, until I can find a friend to help me bleed it, I've been ebraking it to and from work
I would go with the SI one cheaper and you dont have ABS like the ITR so why do you need the bigger line
i have gsr conversion front and rear on my 92 hatch . wit...15/16 m/c and booster..plus a 40/40 proportional valve (40/40 Prop..valve.are or disk front and rear)..and it work good.......40/30 is for disk.and drum.......my setup work great....plus with the 15/16 it jus bolt on my civic wit no fabrication on that one...line...on the 1" m/c.........but if u race ur car alot maybe bigger is better......haha....? my 3 cents..
What are you doing? Change your name back to "The Avenger" and have your fun with that name and not mine.
[Modified by Jedi Master, 11:34 PM 5/27/2002]
My advice to you Craig, is to do the job right in the first place. Get the Si prop valve & 1" mc/brake booster. So you wont have any reservation in your mind on whether or not everything is working properly or what not.
I used the above components on a 6th gen Civic without the need to rebend any lines. It fits like warm apple pie...oh wait...that sounded wrong. You know what I mean.
not true...Ex's are still drums in the rear
I also have the ITR M/C and booster upgrade, It requires less pedal travel for equal braking power.
[Modified by 6ghatch, 11:29 AM 5/28/2002]
When I looked into it, the only thing different was the Master Cylinder assy.
here are some part #'s DIRECT from Honda!!!!!!!!!!!
1997 3dr CX
Master cylinder 46100-S04-A02
Power booster 46400-S04-N11
Porp valve 46210-S04-902
2000 2DR SI
Master cylinder 46100-S04-A12
The Master Cylinder is a little larger to hold and move more fluid on the SI because the rear disk take more fluid then the drums. THAT IS ALL! I took a lot of time and effort to find out all this info so I hope this helps people who are doing the swap.
Back to the question, with a Five lug swap I would do the ITR MC and Power Booster. It's a simple bolt in and worth the extra $100. The larger calipers will take more fluid and the SI MC and booster may not be able to move enough fluid. I did the ITR MC and booster using SI brakes and it made a good difference.
[Modified by 6ghatch, 9:30 AM 5/29/2002]
1997 3dr CX
2000 2DR SI
Isn't the swapping over the entire brake booster a bitch? I heard you have to remove the dash of the car.
I'm doing GSR front and rear brakes this weekend in my 92 Hatch, and I was planning on using a 99-00 Si 15/16th's master cylinder, and a 99-00 Si 40/40 prop valve. I wasn't planning on changing the booster...Do I have to? Are my MC and prop valve choices suitable. Im also gonna be running SS brake lines, aem pads, and powerstop rotors.
