fuel pressure regulator in lxi
Old Apr 8, 2007 | 10:07 AM
lxiaccord's Avatar
Default fuel pressure regulator in lxi
i was wondering if you could put an adjustable fuel pressure regulator in a 88 accord lxi and if so where would you put the lines, thanks
Old Apr 11, 2007 | 04:28 AM
daamizin1's Avatar
Default Re: fuel pressure regulator in lxi (lxiaccord)
You can, but what other mods do you have? You wont see much from messing with the fuel pressure if your stock. Just start off with basic I/H/E. You can use a 90-93 teg CAI you just need to mod it a little and pacesetter makes a OK header and exhaust. You can also get a golden eagle cam gear on 3geez.com from the group buy and you can mod a B18 or B16 intake manifold to fit fairly easy.
Old Apr 11, 2007 | 08:19 AM
standbackimapro's Avatar
You wont get any performance at all, youll end up putting to much or too little fuel and your car will be running like ****
You only need a FPR when you have modifications that call for more fuel
IntegraGSR-Turbo
Feb 27, 2007 07:16 PM
NuclearB18B
Sep 19, 2003 06:20 AM
SleepinAround
Jul 16, 2002 05:12 AM
