92 ACCORD BRAKE LAMP
Old Apr 8, 2007 | 09:32 AM
sonson6's Avatar
Default 92 ACCORD BRAKE LAMP
RECENTLY ONCE IN A WHILE WHEN IM DRIVING THE BRAKE LIGHT WILL FLASH ON AND OFF I CHECKED AND I HAVE ENUF BRAKE FLUID AND LAST NIGHT THE BRAKE LAMP LIGHT CAME ON CAN YALL HELP ME
Old Apr 8, 2007 | 11:16 AM
BLKFLSH's Avatar
Default Re: 92 ACCORD BRAKE LAMP (sonson6)
Take the cap off the brake fluid, and push the rubber thing back up into the cap. This should eliminate the light, if it's the same light we're talking about. If it's the brake lamp indicator, your brake lights might not be working.
Old Apr 8, 2007 | 11:42 AM
falconator's Avatar
Doesn't the brake indicator lamp light up when a brake light is out?
Old Apr 8, 2007 | 04:09 PM
The-Kid's Avatar
as the other 2 people replied. Check your brake light. As someone to step on the brake pedal for you and you check the brake lights in the back. Happened to me once too.
Old Apr 8, 2007 | 05:58 PM
JDM_DC4_Fanatic's Avatar
Default Re: (The-Kid)
if the brake icon lit up on the dash then it could be the float in the resivoir, however, if the brake lamp indicator lit up (same as when the doors are open) then you either have a loose connection, or a burnt out bulb, and you should check both of them out.
Manmeetsingh
May 20, 2014 08:06 PM
white99accordEX
Dec 22, 2005 04:08 AM
Fly1865
Jul 28, 2005 02:03 PM
EuRoBrO
Dec 1, 2003 01:32 PM
SlowazzGSR
Jun 7, 2002 10:30 PM
