Reducing Wheel Hop
Old Apr 8, 2007 | 08:36 AM
1994PreludeSi's Avatar
Default Reducing Wheel Hop
I was just wondering what would reduce wheel hop besides a traction bar system.
I saw that it was about $350 shipped without the front torque mount from explicit speed performance...
*EDIT*
Sorry, Should have used search first...
Old Apr 8, 2007 | 08:47 AM
hu's Avatar
hu
Stiffer motor mounts. Try innovative mounts from Robear racing.
Nothing beats a traction bar, though.
There are no cheap ways around wheel hop!
Old Apr 8, 2007 | 09:40 AM
clemsoncb7's Avatar
Default Re: Reducing Wheel Hop (1994PreludeSi)
My PFI speed traction bar is on ebay for $100
Max
Old Apr 8, 2007 | 09:54 AM
LukieLuc's Avatar
Default Re: Reducing Wheel Hop (clemsoncb7)
40$ for energy suspension motor mount inserts
Old Apr 8, 2007 | 01:43 PM
street_ride14's Avatar
You don't need none of that .. Just learn to take off smooth. Each car // driver will have their own technique. I think tires and tire pressure make big differences on take-off. Just learn your car. I have a stock front crossmember and OEM motor mount inserts and no wheel hop for me.
Old Apr 8, 2007 | 02:00 PM
92hondalude's Avatar
Default Re: (street_ride14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ride14 &raquo;</TD></TR><TR><TD CLASS="quote">You don't need none of that .. Just learn to take off smooth. Each car // driver will have their own technique. I think tires and tire pressure make big differences on take-off. Just learn your car. I have a stock front crossmember and OEM motor mount inserts and no wheel hop for me.
what suspension do you have?
Old Apr 8, 2007 | 02:06 PM
Default Re: (92hondalude)
Lowered roughly 3 inches on skunk2 sleeves paired with tokico blues, not the best combo .. but gets it done for now.
Old Apr 8, 2007 | 03:10 PM
clemsoncb7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ride14 &raquo;</TD></TR><TR><TD CLASS="quote">You don't need none of that .. Just learn to take off smooth. Each car // driver will have their own technique. I think tires and tire pressure make big differences on take-off. Just learn your car. I have a stock front crossmember and OEM motor mount inserts and no wheel hop for me. </TD></TR></TABLE>
Yes that is certainly part of it, but that only goes so far, when you're making more power you need more assistance than just "knowing the car". I take it you drive a relatively stock car...
Max
Old Apr 8, 2007 | 03:58 PM
Hawkze_2.3's Avatar
Haha, and what kind of power are you making? It isn't much if you don't have wheel hop on a FWD Prelude without any aforementioned traction stuff.
Old Apr 8, 2007 | 04:23 PM
Default Re: (Hawkze_2.3)
I got the basis bolt-ons, nothing too major. Lets say this ... If I had 200 whp N/A on my lude ( which I don't ) , I would still ease off the clutch rather than just popping it right off the line. Maybe LSD tranny would help on wheel hop, The only wheel hop I experience is when i pop the clutch fast during take off. So I learned not to do that. That and I expereinced with tire compounds, hard to soft.
Old Apr 8, 2007 | 04:28 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ride14 &raquo;</TD></TR><TR><TD CLASS="quote">I got the basis bolt-ons, nothing too major. Lets say this ... If I had 200 whp N/A on my lude ( which I don't ) , I would still ease off the clutch rather than just popping it right off the line. Maybe LSD tranny would help on wheel hop, The only wheel hop I experience is when i pop the clutch fast during take off. So I learned not to do that. That and I expereinced with tire compounds, hard to soft.
True, but bottom line is better traction and less wheel hop = faster car. Even though it can be avoided, you still loose some time feathering the clutch...
Old Apr 8, 2007 | 04:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
True, but bottom line is better traction and less wheel hop = faster car. Even though it can be avoided, you still loose some time feathering the clutch...</TD></TR></TABLE>
Old Apr 8, 2007 | 05:53 PM
thomas188's Avatar
I don't see much wheel hop myself in my boosted lude. I find it that I seem to get a lot more acceleration anyways by feathering the clutch on take off. You are not going anywhere if you are spinning a lot, nor are you going anywhere fast if your tire (tires) are bouncing on the road. I have to feather the clutch on take off, and then feather the gas upon entering full boost due to my stock suspension not wanting to keep the front end down on the ground....Your problem could be worse ya know
Old Apr 8, 2007 | 06:12 PM
Default Re: (thomas188)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thomas188 &raquo;</TD></TR><TR><TD CLASS="quote">I don't see much wheel hop myself in my boosted lude. I find it that I seem to get a lot more acceleration anyways by feathering the clutch on take off. You are not going anywhere if you are spinning a lot, nor are you going anywhere fast if your tire (tires) are bouncing on the road. I have to feather the clutch on take off, and then feather the gas upon entering full boost due to my stock suspension not wanting to keep the front end down on the ground....Your problem could be worse ya know </TD></TR></TABLE>
i would loveitif my tires would just spin.
slicks comming monday that should help some.
Old Apr 8, 2007 | 07:21 PM
93sivtec's Avatar
Radius Rod bushings help also,energy go for about 30$
Old Apr 9, 2007 | 06:05 AM
bluedlude's Avatar
new set of tires
Old Apr 9, 2007 | 06:16 AM
Default Re: (93sivtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93sivtec &raquo;</TD></TR><TR><TD CLASS="quote">Radius Rod bushings help also,energy go for about 30$</TD></TR></TABLE>
where?
Old Apr 9, 2007 | 07:07 AM
577HondaPrelude's Avatar
shameless plug:
Or you could use a solid spherical bearing to replace the rubber radius rod bushings.
http://www.mckinneyraceworks.c...id=32
Old Apr 9, 2007 | 08:21 AM
bb_one's Avatar
Default Re: (577HondaPrelude)
, I am really liking that solid spherical bearing. I think I will place an order and give it a try. Funny how I was thinking about modifying the stock rubber bushings for something in the same fashion.
Old Apr 9, 2007 | 09:53 AM
McLude2nR's Avatar
Alot more power = no hop and more spin
Ask me how I know
Old Apr 9, 2007 | 10:29 AM
bonh's Avatar
some people say an engine damper helps reduce wheel hop.
Old Apr 9, 2007 | 02:30 PM
93sivtec's Avatar
Where u ask.....I dont know my mechanic got mine for me,28.99.But I assume u could find them online......GOOGLE.
Old Apr 9, 2007 | 02:36 PM
93sivtec's Avatar
I just found the energy suspension radius rod bushing for 20 bucks..... hit suspensions.com up. And dont say I never did anything for u..... just kidding I would like to do the outter tie bars and lower ball joints,but that is spendy.
Old Apr 9, 2007 | 02:38 PM
DJ Hookid's Avatar
I heard the Ingalls torque damper is pretty good.
Old Apr 9, 2007 | 09:14 PM
ciremulb5's Avatar
Default Re: Reducing Wheel Hop (DJ Hookid)
My buddy has an '96 Accord, which is hardly a Prelude, but he has 17'' wrapped in Kumhos and has no wheel hop whatsoever, and can also take a hard turn doing 50mph just fine. Has tried to spin them off the line, and it's impossible (at least in the Accord haha)
