b20b ls cams
Old Apr 8, 2007 | 07:10 AM
b20efmike's Avatar
Default b20b ls cams
hey i got my b20b runing good it was a cam sensor wire that gose to the dizzy was cut so i made a new wire to it so its alll good now ...
but i was wundering if i should but a set of LS cams in my car because the b20b head is the same as a LS head but diffrent cams
do u think this would make some more power ??
Old Apr 8, 2007 | 08:55 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: b20b ls cams (b20efmike)
Depending on your goals it's not the worst idea i've heard.
Frankly even on a mild built or plans for boost i'd look a wee bit larger then stock LS cams.
So what are you looking to do with this car? Please give every detail about it's life like how often you drive what kind of gas you want to use, it'll help us give you a better anwser.
sakasaku
Oct 19, 2010 04:28 PM
91redteg
Aug 7, 2007 09:50 PM
