bad rack and pinion?
Old Apr 7, 2007 | 08:53 PM
jry2598's Avatar
Default bad rack and pinion?
Well it is like this, i thought it was my tie rod so i changed both inner and outer tie rod, rack end bushing, and upper control arm, lower ball joint..... the vibration went away for like two weeks....everything was stiff....couldnt be happeir. but now everything is back to how it was... knocking on rough road, vibrating like it up and down movement. So i took it to the shop to realign my si hatch and for them to check what else could be wrong....i even was with them for a hour....they told me they were stump...... so can this mean my rack and pinion is toast and need a new one.... im starting to pull my hair and drive this bitch off a cliff, if i cant fix this ****....put to much money in this problem...I need to fix before i swap my engine....sorry if this didnt make any sense and i do have my flame suit on in case.......by the way i did "SEARCH""""
Old Apr 7, 2007 | 11:08 PM
Tyson's Avatar
Default Re: bad rack and pinion? (jry2598)
did you ever adjust the gearbox pinion?
Old Apr 9, 2007 | 08:48 AM
jry2598's Avatar
Default Re: bad rack and pinion? (Tyson)
i told the mechanic guy to adjust the gear box and he told me there is no such thing......he said honda use rack and pinion only no gear box...
Old Apr 9, 2007 | 10:20 AM
Tyson's Avatar
thers a big lock nut on the other side of the pinion. you must adjust that in conjunction with replacing the rack end bushing. its in the helms.
relentlesstech
10
Feb 12, 2025 09:24 PM
Mr. Em1
21
Jun 7, 2010 03:24 PM
Acurazor
May 24, 2009 12:19 PM
PandaBear
Suspension & Brakes
Jul 22, 2006 08:26 AM
MiX
Dec 27, 2004 07:32 PM
