99 Accord coolant Drain Bolt
Old May 27, 2002 | 06:20 AM
Guitarman's Avatar
Default 99 Accord coolant Drain Bolt
Can anyone describe where the coolant 'Drain Bolt' is located on the block. The manual appears to be a hex head bolt (13mm). But when I remove the bolt oil comes out rather than coolant. If you know please help. Thanks
Old May 27, 2002 | 10:43 AM
Johnny Gasparini's Avatar
I didn't ask for a dime.
Default Re: 99 Accord coolant Drain Bolt (Guitarman)
Loosen the drain plug on the bottom of the radiator. The coolant will drain through the splash guard. Remove the drain bolt and washer from the engine block.
Old May 27, 2002 | 11:43 AM
4doorH22's Avatar
Default Re: 99 Accord coolant Drain Bolt (JSM)
If it's anything like mine, and I'm sure it is, you can't see it from under the car 'cause the intermediate shaft is in the way and the block has a little like ledge at the bottom that obsures the view of the bolt. It's to the left and up a bit from the oil filter. You just have to feel for it, then fit a socket (I use a shallow socket with ~4 inch extension) on it and pull like a M-Fer until it breaks loose.
Old May 27, 2002 | 11:44 AM
4doorH22's Avatar
Oh, it's a lot bigger than 13mm. At least 17 mm and it uses a big-*** washer.
missionaryrider
Jan 15, 2010 08:23 AM
Tokonut
Mar 1, 2009 06:33 PM
OogalyDoogaly
Honda Motorcycles
Feb 4, 2008 05:31 AM
91H4hatch
Dec 26, 2006 04:51 PM
Monty
Jul 23, 2002 03:56 AM
