heater blower
Old Apr 7, 2007 | 04:55 PM
95lscivic's Avatar
Default heater blower
today after finally getting my climate control unit in, i checked all the functions of the unit to make sure they worked. everything worked properly until i turned the blower on. nothing happend 1 through 4. i proceded and checked the 30a fuse, nothing.
is there anything else that i could be? or do i have to replace the blower itself to make the heater work?
ethan.
Old Apr 7, 2007 | 05:55 PM
Crx Jimmy's Avatar
Default Re: heater blower (95lscivic)
bang on it with a hammer, no joke. I have seen these rust up and seize. Bang the outside of the unit it might start going again.
Old Apr 7, 2007 | 10:23 PM
95lscivic's Avatar
Default Re: heater blower (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">bang on it with a hammer, no joke. I have seen these rust up and seize. Bang the outside of the unit it might start going again. </TD></TR></TABLE>
lol ill try that. it hasn't been used in a very long time, im kind of resurecting this crx so that might be it.
however, if that does not work, is there any other fuses i could check, or relays? i really don't want to have to replace this as it is not cheap.
Old Apr 8, 2007 | 06:53 AM
~sp33~'s Avatar
EFB055
Theres a resistor that needs replacing it sits behind the glovebox in my civic. Take it out and one of the springs/coils will be broken so open circuit = no blowing.
Old Apr 8, 2007 | 09:07 AM
1990crxsir's Avatar
I am having the same problem with a sedan I just bought.
I checked the wires running to the motor with a tester and found it was getting power. I figured it was the motor so I took it out, spun the fan, then tried it again. It worked! I turned it off and tried to start it again. Nothing. Repeated the last couple steps and was able to get it to work until I shut it off again.
I have seen electric motors get dead spots in them but never saw one that needed a "helper spin" to get going every time I try to use it.
BTW.... Once the motor is running it is strong.
If your blower motor is like mine I think the best thing is to replace it. Unless this condition is caused by something else?
nk2k2
Nov 6, 2005 12:53 PM
Mefain
Jan 21, 2005 03:38 AM
headhunter
Jan 12, 2005 03:03 AM
REDTOPAlchemy
Aug 29, 2004 07:33 PM
iNetForce
Apr 3, 2004 07:34 PM
