DB8 B18c: ELECTRICAL ISSUE!!!
Ok b-series fanatics,
i have a problem. Ok i rebuilt my alternator tested and passed.
Charged my battery and passed.
I drive my car and my car is fine for awhile then, power starts slowly draining and i noticed my ABS light went off and my clutch was off (had to switch into first by pressing clutch almost halfway to switch or it will grind). When i turned my signal lights on all my lights would blink simultaneously as the blinking signal...I'm goin to change fuses cuz some popped but is it possible i have a bad fuse box now?
Sounds like u got a couple problems. First, if u've replaced the alternator and battery, and the battery's still going dead, it's likely that eather the fuse is blown or somehow the cable going from the alternator to the fuse box isn't hooked up. is the battery light on (the one on ur dash)? Also, ur ABS light should always be off except for when u first start ur car, if it's on while ur driving that means it's not working. About ur lights, sounds like ur hazard lights are turning on... Maybe the wires aren't connected right. About ur clutch, what do u mean ur clutch was off? The clutch doesn't use any electricity, it's all mechanical. If it's grinding in first ur eather not completly stopped or u need to bleed or replace ur clutch.
wow, well bro hate to break it down to ya but i troubleshot it.... it was my fuse box (main fuse box/enigine bay). O yea and yea if u dunno wut i'm talkin about on the clutch on 98 DB8's they have a fuse called "clutch master relay" i KNOW my car and can tell when it's off. I was not tryin to sound stupid but i think u never experienced wut happened to me i guess >_<
