TURBO MADNESS!!!
im looking for a piggyback ecu much like the piggyback that comes in the edelbrock performer x kit thats ready to go no problem...does anyone have one or know of one? or is there something i can get instead like a chip or something...its a 94 integra GSR turbo...5 speeder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo »</TD></TR><TR><TD CLASS="quote">I thought with chome you have to swap chips with every retune?</TD></TR></TABLE>
why would you have to do that? i havent heard anything about that. As far as I know, you still burn the chip and run it off the factory ecu just like the rest.
Not really swap chips. It's more update because your fuel/ignition tables will change. So they just fix what they need to and then burn it onto your Chip. What they use to make changes is probably a Real Time Prograing device like Moates Ostrich emulator. Which pretends to be a chip but isn't but you can make changes on the fly. Then when you have set to what you need. You burn it to a chip.
JDMlyfestyle
Apr 7, 2004 08:37 AM
