Wiring Pinout Information Needed (and CAN Protocols?)
Old Apr 7, 2007 | 01:55 PM
Hunter's Avatar
Default Wiring Pinout Information Needed (and CAN Protocols?)
I am wiring up a data logger in my ITR and need to splice into some signals in the stock wiring harness.
The channels I am looking for are Engine RPM, all four wheel speeds, water temp, and oil pressure. Anyone have some wiring diagrams they could scan for me?
I am also wanting to monitor lambda. Anyone know what the specs (pinout/calibration) are on the stock o2 sensors? Not sure if I'll be able to splice into that signal or not.
And... I know this is getting WAY over most of H-T's head... but I figure some of you have looked into it... CAN Protocols (or RS232) for Honda ECU's. It would be great if I could sample all of these channels coming out of the ECU, however, if no one has any information on it... it is way too time consuming to decipher.
Modified by Hunter at 6:10 PM 4/7/2007
Old Apr 7, 2007 | 07:37 PM
sicones's Avatar
Default Re: Wiring Pinout Information Needed (Hunter)
honda ECUs 2004/5? and older don't use CAN protocols...FYI
they use ISO9141, which has a similar bit format as RS232, CAN is totally different
Old Apr 7, 2007 | 07:44 PM
Bradstard's Avatar
OBD2a OBD2b Function OBD1 Color Notes
A01 B05 Injector 4 A02 Yellow
A02 B04 Injector 3 A05 Light Blue
A03 B03 Injector 2 A03 Red
A04 B11 Injector 1 A01 Brown
A05 A08 SO2H No connection on OBD1
A06 C01 PO2H A06 Orange/black
A08 B12 VTS A04 Orange/White
A09 B20 LG1 A26 Black/Red
A10 B02 PG1 A23 Black
A11 B01 IGP1 A25 Yellow/Black
A12 B23 IACV A09 Green/White
A15 A06 PCS A20 Red
A16 A16 FLR A07 Green/Yellow
A17 A17 ACC A15 Black/Red
A18 A18 MIL A13 Green/Orange
A19 A02 ALTC A16 White/Yellow No connection on D16Y8 P2Nb
A20 B13 ICM A21 Red/Green
A22 B22 LG2 B02 Brown
A23 B10 PG2 A24 Black
A24 B09 ICP2 B01 Yellow Black
A27 A20 FANC A12 Yellow/Green
C01 C31 CKFP No connection on OBD1
C02 C08 CKPP B15 Blue/Green
C03 C20 TDCP B13 Orange/Blue
C04 C29 CYPP B11 Orange
C05 A27 ACS B05 Blue/Red
C06 A24 STS B09 Blue/White
C07 A10 SCS D04 Brown
C10 B21 VBU D01 White/Blue
C11 C22 CKFM No connection on OBD1
C12 C09 CKPM B16 Blue/Yellow
C13 C21 TDCM B14 White/Blue
C14 C30 CYPM B12 White
C15 C10 VTM D06 Orange/Green Connected to VTS on OBD2a
C16 A26 PSW B08 Brown/Red
C17 C05 ALTF D09 Pink No connection on D16Y8 P2Nb
C18 C23 VSS B10 Yellow/Blue
D01 C27 TPS D11 Pink/Black
D02 C26 ECT D13 Red/White
D03 C17 MAP D17 Pink/White
D04 C19 VCC1 D19 Yellow/Green
D05 A32 BKSM D02 Greem/White
D06 C03 KS D03 Red/Green No connection on P08, P28
D07 C16 PO2S D14 White
D08 C25 IAT D15
D10 C28 VCC2 D20 Yellow/White
D11 C18 SG2 D22 Green/White
D12 C07 SG1 D21 Green/Blue
D14 A23 SO2S No connection on OBD1
D16 A30 EL D10 Green/Red No connection on D16Y8 P2Nb
Old Apr 8, 2007 | 08:33 AM
Hunter's Avatar
Default Re: Wiring Pinout Information Needed (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">honda ECUs 2004/5? and older don't use CAN protocols...FYI
they use ISO9141, which has a similar bit format as RS232, CAN is totally different </TD></TR></TABLE>
didn't know honda hasn't used CAN until the past few years... and i know can and rs232 are totally different. i wasn't sure what sort of communications were used on hondas in 00-01 and the dash i am using is capable of sampling data from can as well as rs232 protocols. thanks.
Thanks for the pinout bradstard! Any pinout info on the ABS controller?
coa132435
Jul 5, 2019 11:35 AM
itsmebeaner1987
Audio / Security / Video
Nov 4, 2004 01:57 AM
tico_1998
May 6, 2003 02:01 PM
