engine building thoery: bearings?
new rod and main bearings come with what looks like a porous/semi-porous inner surface. i was playing with some of my old rod bearings(which were not removed because of failure) and decided to polish them up with some mother's brand metal polish(yeah i get really bored sometimes). when i was done, they were incredibly smooth and looked/felt like the journals on the crank.
here's where the thoery comes in:
would the polished/smoother surface be better due to the decreased friction, or does the original finish act as a "magnet" to hold oil against it?
i doubt that i affected the clearance of the bearing, but i supposed it is possible. any thoughts on this are apprecitaed!
Whered did you get your new bearing from. You crank/rods spin on a film of oil dont actually sit on the bearing. I dont think a smooth shiny finish would do anything.
thats kind of what i figured. if being smooth/shiny was better, they would probably come that way from honda. (they are OEM bearings btw) would polishing them be detrimental to their functionality?
and no i didnt do this to the new ones!
OEM bearings come with a coating on them that is for protection when first installed/dry starts. polishing bearings may promote lubricity in theory but at what cost? I think you raise an interesting idea though. Try asking a professional engine builder or machinist
no the coating is not for ''cold starts'' it is there for protection and oil retention, but not ment to be worn.. 1 good rub and the shiet is gone.
if so people would be waisting money when coating bearings..
integra3586
21
Oct 30, 2009 09:16 PM
pkolaboy
Jan 9, 2008 08:50 PM
Dyzee
10
Apr 28, 2004 11:56 AM
