Quick question about LSVTEC Compression Ratio...
Old Apr 7, 2007 | 10:16 AM
SiB16A's Avatar
Default Quick question about LSVTEC Compression Ratio...
found what i needed. thanks guys
Modified by SiB16A at 11:36 PM 1/22/2008
Old Apr 7, 2007 | 11:27 AM
SiB16A's Avatar
Default Re: Quick question about LSVTEC Compression Ratio... (SiB16A)
anyone?
Old Apr 7, 2007 | 11:41 AM
gibsanez's Avatar
The Zeal calc has been known to be a little more accurate. The GSR head has a smaller combustion chamber, so your static CR will be higher. You could consider the P61 B17 pistons which have a flat dome, for roughly a 10.8:1 CR. But also remember, when you run a longer cam, you lose dynamic CR, so your calculated 11:1 CR could be closer to 9 or 10:1, depending on your cam choice.
Old Apr 7, 2007 | 12:16 PM
doood's Avatar
been there done that
the zeal calculator takes into account the different compression heights. it's a little more accurate. but numbers from any of these calculators should only be taken as general estimations.
Old Apr 7, 2007 | 02:54 PM
SiB16A's Avatar
Default Re: Quick question about LSVTEC Compression Ratio... (doood)
How do i find what compression i am going to be at? Since the two calcultors are just general estimations.
Old Apr 7, 2007 | 08:36 PM
SiB16A's Avatar
up
Old Apr 7, 2007 | 09:40 PM
aut0tek's Avatar
A piece of plexiglass, a drill bit, a syringe and some liquid.
Drill hole in plexi for syringe to fit in.
Place the plexi over the head (head upside-down, spark plugs installed)
fill each combustion chamber with liquid until it touches the top of the plexi, measuring each time you fill the syringe.
get all liquid back out using syringe and measure to make sure you were accurate the first time.
You could try to do the same to block, but I'd just input your cc measurements for the head into a calc and use the calc's measurements for the block, call it a day... Oh, but even then it's still an estimate.
-aut0
Old Apr 8, 2007 | 10:05 PM
SiB16A's Avatar
anyone else?
Old Apr 9, 2007 | 11:57 AM
SiB16A's Avatar
Old Apr 9, 2007 | 05:40 PM
mar778c's Avatar
Community Builder
Community Influencer
have your motor cc'd then you'll know.
Old Apr 9, 2007 | 06:07 PM
Timmay's Avatar
from what i understand Zeal has the wrong specs on the b18a/b block.. isnt the gsr and ls deck height supposed to be the same?
Old Apr 10, 2007 | 05:09 PM
Mike@K-Tuned's Avatar
Very similar engine build to mine. Compression will be 11.8 to 1 assuming that the block has not been decked and the head has not been milled. You got PM.
Rat Rod
Nov 27, 2010 05:08 PM
negusjuda
Aug 24, 2010 09:37 AM
Techna600f4i
Jun 19, 2006 11:49 PM
NSX Bob
Feb 5, 2003 05:52 PM
tsjag17
Jul 9, 2001 04:49 PM
