H23A swap to H22A - NO FUEL!!!
Old Apr 7, 2007 | 04:26 AM
95preludes1's Avatar
Default H23A swap to H22A - NO FUEL!!!
Hey guys I just recently swapped out my H23A motor in my 95 Prelude with a JDM H22A. Used the H23A’s fuel rail and external ignition coil/distributor, now when I go to crank up the car, its not getting any fuel. I even had someone crank the car while I took off the bleeder valve on the fuel rail and it was dry as a bone. I went through the car and I only have 1 sensor that is disconnected (the sensor is dangling near the external ignition coil). I am thinking it is a spare sensor on the H23A since my H22A does not have a sensor for the top radiator hose housing. Anyway anyone have any suggestions?
Old Apr 7, 2007 | 12:00 PM
donger's Avatar
Default Re: H23A swap to H22A - NO FUEL!!! (95preludes1)
i just did the same swap and i swapped the upper radiator hose housings since my h23 one had the sensor and my h22 one didnt. not sure about the fuel prob.
Old Apr 7, 2007 | 12:05 PM
Fly1865's Avatar
There is a ground wire that bolts to the head on the distributor side. I did the same thing, swapped the motor out, forgot to bolt that wire up. Cranked the motor, fuel pump didn't turn on. Found the wire and bolted it to the head, cranked the motor again and it started right up.
Old Apr 7, 2007 | 12:09 PM
jdmlude5
Guest
Posts: n/a
Default Re: H23A swap to H22A - NO FUEL!!! (donger)
i swapped my h23 for a jdm h22a. the h22 didnt have the sensor upper water inlet either. i just left it off. still aint plugged into anything. car runs fine
Old Apr 9, 2007 | 07:30 AM
user 720822-1's Avatar
Default Re: H23A swap to H22A - NO FUEL!!! (jdmlude5)
Quick question...
Your talking about this one right? (see pic)
I'm swapping at the moment and my H23 has a sensor on it and the H22 doesn't, so I've got a connector which can't be plugged (I'm using my H23 wiring harness).
So this is what your talking about to leave it off?
And should I leave it off (can it hurt)? Or is it wise to get it from my H23 OBD1?
Thx
Old Apr 9, 2007 | 08:29 AM
flyrod's Avatar
Default Re: H23A swap to H22A - NO FUEL!!! (Black-Engine)
Check the ground to the head. Make sure the CEL comes on then goes off. You should be able to hear the fuel pump. Check the ECU wiring and main relay if there is still no fuel.
Old Apr 9, 2007 | 01:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-Engine &raquo;</TD></TR><TR><TD CLASS="quote">Quick question...
Thx</TD></TR></TABLE>
Anyone?
Old Apr 9, 2007 | 01:53 PM
NukeeZoid's Avatar
that really isnt a big deal...when i swapped the H22A into my car...there is no sensor to plug in if u use the H23 harness....car still ran...
Old Apr 9, 2007 | 02:35 PM
donger's Avatar
Anyone?</TD></TR></TABLE>
yes, thats the one we're talking about. some poeple have swapped it and others have left it and both have turned out fine it seems.
Old Apr 9, 2007 | 04:52 PM
jdmlude5
Guest
Posts: n/a
yeah i left that alone i didnt swap that sensor. the wire just hangs there not connected to anything. and my car runs fine.
Old Apr 10, 2007 | 01:34 AM
Ok, Thx guys!
My swap is almost ready!!!
Old Apr 10, 2007 | 06:33 PM
JT's Avatar
JT
The sensor on the water housing is for the AC fan control. I swapped the housing from the H23.
Old Apr 11, 2007 | 07:01 AM
Default Re: H23A swap to H22A - NO FUEL!!! (JT)
Ok, so having A/C you must take the housing from the H23 or it won't work?! In my case, I have A/C
fastlane2
May 10, 2011 12:52 AM
koreachangsu
Sep 12, 2006 06:59 PM
sprayedlude93
Jun 24, 2006 07:20 PM
delirious1520
Dec 27, 2005 04:59 PM
crxhybrid1320
Jul 25, 2003 08:10 PM
