CRACKED oil and BAD alternator
i have a 90 crx si with a first gen b16 swap. the only thing is that i cracked my oil pan and i have a bad alternator that needs replacing. i was just wondering if i could use any b-series oil pan and alternator, or does it have to be first gen b16 specific??
THANKS FOR THE HELP
THANKS FOR THE HELP
I'm not sure about the oil pan, although I have a B18A (LS) block and I'm using a Type R pan...I suppose they're all the same but some have windage a windage tra. As for the alternator, you'll have to check the plugs because different year B series (obd0/1/2) have different plugs..
You can use any OBD0 or OBD1 B-series alternator, the plugs are the same.
As for the oil pan, you can use a 90-93 Integra oil pan, it's the same as the B16A one.
jetpilot
Jul 11, 2004 10:09 AM
