car starts up and then shut down
Old Apr 6, 2007 | 10:41 PM
MI4$DC5's Avatar
Default car starts up and then shut down
I just swapped a b20/vtec into my 94 eg with a p28chipped. Now when i start it up it cuts on revs hella high and shuts down. Im stumped. Im going to check the plugs on the intake manifold to double check that they are in the right location. any more ideas to why it would do this? Im throwning a code, but its for vtec.
Old Apr 6, 2007 | 10:52 PM
spork motorsports's Avatar
* B A N N E D *
Default Re: car starts up and then shut down (MI4EH2)
its probably the ecu restting let it do its thing
it goes from 800-1500 repeadtley over and over then it finds idle, then if any ot woll throw a cel
Old Apr 7, 2007 | 10:12 PM
MI4$DC5's Avatar
Default Re: car starts up and then shut down (spork motorsports)
no when i cut the car on, it revs high for like 1 second, and then cuts off
Old Apr 10, 2007 | 06:56 PM
MI4$DC5's Avatar
bump for some help....car will cut on with a looping idle sometimes. Most of the time it will start up and cut off immediately. Im going to blow this hatch up
Old Apr 11, 2007 | 07:18 AM
MI4$DC5's Avatar
i just tested the TPS sensor and Map sensor and they are good.
Old Apr 11, 2007 | 07:29 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MI4EH2 &raquo;</TD></TR><TR><TD CLASS="quote">i just tested the TPS sensor and Map sensor and they are good.</TD></TR></TABLE>
you have a vacuum leak. this happen to me once when i forgot to plug in the hose to the pcv valve. double check all hoses going to the I/M. look for cracks, tears, etc.
Old Apr 11, 2007 | 10:07 AM
MI4$DC5's Avatar
Default Re: car starts up and then shut down (philosofy1)
im going to check that rightnow.
perpetualburn
Jan 13, 2008 12:43 AM
invisible
10
Mar 17, 2007 11:22 PM
92eg6_pino
Aug 16, 2005 07:53 PM
Pete_SI
Mar 22, 2005 03:12 AM
