Wiring headlights for EG6 Civic 92-95
Old Apr 6, 2007 | 10:07 PM
kos99ngel's Avatar
Default Wiring headlights for EG6 Civic 92-95
My EG6 got stolen and they cut the wiring for the headlight I went off to the Honda dealer and got me the connector with the 3 wires the problems is the wires are not color coded there just red anyone know to wired the properly?
Thanks
Old Apr 7, 2007 | 01:40 PM
kos99ngel's Avatar
Default Re: Wiring headlights for EG6 Civic 92-95 (kos99ngel)
come on anyone help plz
Old Apr 7, 2007 | 10:18 PM
kos99ngel's Avatar
bump help
Old Apr 7, 2007 | 11:47 PM
Vintech's Avatar
try searching for a PDF version of the manual.
Old Apr 8, 2007 | 12:08 PM
sireg6's Avatar
ok well if your plug looks like this then it should be easy...but if not maybe you can pop the tabs and follow the wires so you can color match...Dont know if this helps or not but hey better than nothing good luck
Old Apr 8, 2007 | 04:56 PM
kos99ngel's Avatar
Default Re: Wiring headlights for EG6 Civic 92-95 (sireg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sireg6 &raquo;</TD></TR><TR><TD CLASS="quote">ok well if your plug looks like this then it should be easy...but if not maybe you can pop the tabs and follow the wires so you can color match...Dont know if this helps or not but hey better than nothing good luck
Hey it looks like the
RED/BLUE goes with the High Beam
BLACK goes with the Low Beam
RED/WHITE goes with the Ground
Just making sure...............
Old Apr 8, 2007 | 05:24 PM
sireg6's Avatar
no the black is your ground and red/white is low beam
TweakedTT
26
Aug 10, 2008 06:26 PM
Ritchie
Jul 23, 2006 10:39 PM
TapOrSnap
Feb 8, 2006 05:29 PM
Atheist
Apr 3, 2005 04:34 PM
