3 pt. carbing bar, interferes with brake reservoir.
Old Apr 6, 2007 | 06:39 PM
jvtec95's Avatar
Default 3 pt. carbing bar, interferes with brake reservoir.
I have a carbing 3 pt. bar for dc2 integras, but when I try to put it on, the brake reservoir is too tall. My integra is a '95, Does anyone know if the 98+ reservoir is shorter, or what do I have to do to get it to fit??
Anyone with this bar, please give me some advice!!
Old Apr 6, 2007 | 06:57 PM
PrinceAli132's Avatar
Default Re: 3 pt. carbing bar, interferes with brake reservoir. (jvtec95)
I believe its hitting because the carbing bar is made for a RHD car where the brake booster, master cylinder, and clutch master cylinder are on the other side.
Ali
Old Apr 6, 2007 | 07:23 PM
jvtec95's Avatar
Default Re: 3 pt. carbing bar, interferes with brake reservoir. (PrinceAli132)
Yes, but I've seen other people with the car installed, I want to know what they had to do to make it fit.
Different reservoir? Modified reservoir? I don't really want to modify the bar, looking for options.
Old Apr 6, 2007 | 10:44 PM
00IntegrAllmotoR's Avatar
HT Black OPs
All the ones I've seen cover the reservoir.
Old Apr 6, 2007 | 10:51 PM
RaceMyGhost's Avatar
Default Re: 3 pt. carbing bar, interferes with brake reservoir. (00IntegrAllmotoR)
sell the carbing bar, get yourself a passwordjdm 3pt bar which clears brake master cylinder reservoir. Its also alot stronger then carbings....
Old Apr 7, 2007 | 07:22 AM
jvtec95's Avatar
Default Re: 3 pt. carbing bar, interferes with brake reservoir. (RaceMyGhost)
I like the carbing, and I've had a bad experience with passwordjdm, I also think most of their jdm stuff is a rip-off. Also, the carbing bar weighs ~5 lbs., something the heavy-*** password bar can't claim.
As for being stronger, I kinda doubt it. It has 5 mm aluminum plate, and the firewall connection point is a lot sturdier than the password one. Either way, I'd rather pay a little more for the original than a knock-off.
I know I've seen people use the RHD 3-pt., anyone in here have any advice?
Thanks.
Old Apr 7, 2007 | 07:30 AM
BrOkEn_Dc2's Avatar
Just take the brake reservoir off! That's how you can get it on!
Old Apr 7, 2007 | 08:04 PM
HT Black OPs
Default Re: 3 pt. carbing bar, interferes with brake reservoir. (Spoon07)
Thats why the password is heavier. And you really think lbs matter on a strut bar anyway??
Old Apr 7, 2007 | 10:13 PM
BrOkEn_Dc2's Avatar
I always did think that for some suspension parts(sway bars, strut bars, ect) that heaver was mostly better...
Old Apr 9, 2007 | 10:46 PM
MRed's Avatar
Change out your reservoir or the brake master cylinder and reservoir to the 98 spec. Should clear it. You are right, PJDM is not JDM and is a knockoff.
89hatcher
May 20, 2008 06:29 AM
phan
36
Jul 26, 2004 02:08 PM
Deluzional
Mar 17, 2004 05:40 PM
phantom_sol
11
Dec 7, 2003 05:41 PM
v8killersi
Feb 20, 2003 05:42 PM
