Need some help finishing my compustar alarm install
Old Apr 6, 2007 | 05:28 PM
wreckeddc4's Avatar
Default Need help finishing compustar alarm install
I just started installing my compustar alarm in my 99 gsr, i was wondering how to hook up the trunk pop because of the funky latch setup, also i have a general idea of how to hook up the keyless entry into the doors, lastly and general tips or hints would be greatly appreciated, thanks.
Old Apr 6, 2007 | 05:52 PM
suspendedHatch's Avatar
Default Re: Need help finishing compustar alarm install (wreckeddc4)
If you have power door locks, then you just need negative lock outputs to the lock and unlock wires. Some alarms only have weak mA negative outputs so you may have to use relays to strengthen the output.
For the trunk pop, you should use a universal door lock actuator. It works really good on Hondas/Acuras. The trunk pop solenoids they sell are overkill and take up a ton of space. You will probably want to use some kind of steel cable and a clamp with the door lock actuator. Just try to find a spot to mount it near the latch, you may have to trim some sheet metal and mount it with a backstrap. Ground one wire, and you'll have to send power to the other wire from a relay. Which is ground and which is power depends on whichever orientation makes it pull.
The relays will be wired the same for both the doorlocks and the trunk pop. Your alarm's negative output (whether it's the aux output or the door lock output) goes to 85, loop 86 to 30, and connect 30 to a constant, fused 12V. Connect 87 to the wire going to the actuator/door lock wire. You'll need a seperate relay for the lock, unlock, and trunk pop.
Old Apr 7, 2007 | 05:41 AM
fcm's Avatar
fcm
Old Fart
What is the model number of your Compustar? 94
Old Apr 7, 2007 | 07:49 AM
wreckeddc4's Avatar
Default Re: Need help finishing compustar alarm install (fcm)
the model number of the brain is cm3300 but the alarm itself is a 2W900FM-A with the 2 way remote
Old Apr 7, 2007 | 03:11 PM
bseries_ben's Avatar
you don't have a trunk pop on your hatch unless you added one. the alarm can't pop your hatch unless you already have an actuator
Old Apr 9, 2007 | 07:08 PM
firewalkerr's Avatar
I don't know about the trunck release, but I just did my 98 gsr last week. Finding the right wires was confusing but this helped a lot, it lists all the needed wires, where to find them and the colors:
http://www.commandocaralarms.c...tegra
Once I installed the alarm with keyless entry I cut the unlock wire to the power switches on the doors to slow down anyone trying to get in with a coat hanger. Not a big deal but hopefully it makes the theives waste more time. When they stole my car they just took a crowbar to the top of the door and pried it open, then probably hit the power unlock.
droopy128
Sep 22, 2018 05:47 AM
traxxasx
Dec 15, 2008 06:13 PM
si90rex
Audio / Security / Video
Nov 18, 2008 04:55 AM
the jdmchop
May 10, 2006 08:40 AM
Average DA9
Aug 17, 2004 07:27 PM
