93 JDM h22a with chipped out p28, Wat do u think about a manual Vtec Switch????
Old Apr 6, 2007 | 03:40 PM
duceducecord's Avatar
Default 93 JDM h22a with chipped out p28, Wat do u think about a manual Vtec Switch????
i have a 96 honda accord with a 93 jdm h22a and i was woundering if it would be a good idea to run the vtec solinoid to a button because the p28 that i have, vtec kicks in at 6000rpm but i want it to kick in sooner. Wat do u guys think.
Old Apr 6, 2007 | 03:45 PM
Pullig's Avatar
Default Re: 93 JDM h22a with chipped out p28, Wat do u think about a manual Vtec Switch???? (duceducecord)
why not burn a new chip with the vtec engaging at the rpm you want?
Old Apr 6, 2007 | 04:10 PM
jdmlude5
Guest
Posts: n/a
Default Re: 93 JDM h22a with chipped out p28, Wat do u think about a manual Vtec Switch???? (Pullig)
or jus get a vtec controler just to use for vtec.
Old Apr 6, 2007 | 04:16 PM
SteveoBA8's Avatar
Default Re: 93 JDM h22a with chipped out p28, Wat do u think about a manual Vtec Switch???? (jdmlude5)
Engage that **** at 2500
Old Apr 6, 2007 | 04:48 PM
kulrevon's Avatar
Default Re: 93 JDM h22a with chipped out p28, Wat do u think about a manual Vtec Switch???? (SteveoBA8)
you can make vtec engage earlier but the fuel will not be compensated. So basically you will be running lean until 6000rpm.
Also what chip are you running in the p28.
Old Apr 7, 2007 | 08:56 AM
Default Re: 93 JDM h22a with chipped out p28, Wat do u think about a manual Vtec Switch???? (kulrevon)
if my car was to run lean wouldnt that be bad..... wouldnt it lead to detination? i mean it would be nice to hit it at 2500 rpm but i duno. i think im running a mugen chip or spoon becase i baught the ecu fro my friend
Old Apr 7, 2007 | 09:03 AM
i duno wat chip would be good for my h22. i want the vtec to kick in a lil bit earlier like my stock ecu but the stock ecu kicks in louder but some how lag in the beginning before vtec enguages
Old Apr 7, 2007 | 09:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 &raquo;</TD></TR><TR><TD CLASS="quote">Engage that **** at 2500 </TD></TR></TABLE> isnt that too earlie to hit vtec?
Old Apr 7, 2007 | 09:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude5 &raquo;</TD></TR><TR><TD CLASS="quote">or jus get a vtec controler just to use for vtec.</TD></TR></TABLE> on a budget baby on the way
Old Apr 7, 2007 | 09:35 AM
alphajesse's Avatar
If this chip has vtec engaging at 6k rpm, I'd be amazed if it was tuned to run a H22.
Get a real tuning job.
Also, VTEC engaging at 2500 rpm won't do anything for you but make the car slower. The VTEC lobes on the cam are optimized for high rpm performance.
Your budget is going to do things that will make your car more unreliable and therefore, more expensive. Go back to a stock ECU or get some real engine management.
Old Apr 7, 2007 | 12:47 PM
Default Re: (alphajesse)
alrite kool thanks
sleepgsr
Oct 10, 2007 07:48 AM
reynosop
Apr 16, 2007 07:17 AM
duceducecord
Apr 6, 2007 04:08 PM
slowcrxsib16
Jul 9, 2006 08:49 PM
SSA 1
Jul 27, 2003 09:41 PM
