HELP!!!! Car is reving at full throttle and wont stop!
Old Apr 6, 2007 | 11:48 AM
c r x_s i's Avatar
Default HELP!!!! Car is reving at full throttle and wont stop!
for some reason my throttle is stuck open. my throttle cable is fine. everytime i start the car, for some reason it is being floored. can anyone help me with this???
Old Apr 6, 2007 | 11:50 AM
90ed6's Avatar
Default Re: HELP!!!! Car is reving at full throttle and wont stop! (c r x_s i)
did you do a mpfi swap or do you have an si?
Old Apr 6, 2007 | 11:51 AM
89efDUSTY's Avatar
are you sure you checked all the throttle cable...vaccum lines all hooked up? is there play in the gas pedal
c r x_s i's Avatar
Default Re: HELP!!!! Car is reving at full throttle and wont stop! (90ed6)
its a 91 si with a jdm gsr swap
Old Apr 6, 2007 | 11:52 AM
c r x_s i's Avatar
all vaccum is hooked up.. and the throttle cable has tension on it. the throttle cable is loose
Old Apr 6, 2007 | 11:54 AM
c r x_s i's Avatar
i just replaced my clutch cable today. i drove it on the freeway and it was fine. i came back and let it sit for a little bit. i started it back up and now i have a full throttle
Old Apr 6, 2007 | 11:56 AM
c r x_s i's Avatar
anyone at all ever experience this? if so how did you fix it?
Old Apr 6, 2007 | 11:58 AM
gator88's Avatar
shift faster and make better time now? Be sure you dont have any **** around the throttle body. I helped fix my friends civic that was wide flippin open all of a sudden after gettin back from a drive. seems liek same scenario. HE claimed he never floored it when it was off, but must have, because we took off his intake "arm" thing and we could see the throttle plate thingy wide open. unbolted it, took off all the ****, cleaned it really good with carb cleaner, and now it springs right back. It had all the oily soot **** from the valve cover breather all over the pivots. Might wanna check this out. hope i helped.
Old Apr 6, 2007 | 12:01 PM
c r x_s i's Avatar
Default Re: HELP!!!! Car is reving at full throttle and wont stop! (gator88)
so take apart my throttle body? the flap in the throttle body is fine.. it springs back and forth..
Old Apr 6, 2007 | 12:04 PM
c r x_s i's Avatar
could it have anything to do with the tps??
Old Apr 6, 2007 | 12:08 PM
hafftrak's Avatar
You have a vtec buildup. Take it out and go full throttle up and down your street and burn some of it off.
J/P
Check your gaskets on the throttle body and intake manifold. Sounds like you have an air leak somewhere.
Old Apr 6, 2007 | 12:12 PM
c r x_s i's Avatar
Default Re: (hafftrak)
just double checked the vaccum hoses and the gaskets are fine... anything else?
Old Apr 6, 2007 | 12:18 PM
nomotor's Avatar
this happend to my ls motor after i changed to oil the motor would idle at 4000 rpm, i messed around with the idle screw and loosened up the throttle cable a bit.
Old Apr 6, 2007 | 12:19 PM
c r x_s i's Avatar
Default Re: (c r x_s i)
thanks for the help everyone but it is still stuck at full throttle.. does anyone else have any other suggestions?? could it be the throttle position sensor?
Old Apr 6, 2007 | 12:21 PM
c r x_s i's Avatar
the throttle cable is not tight or lose at all.. its perfect. its adjusted perfectly.. its been fine until today...
Old Apr 6, 2007 | 12:27 PM
nomotor's Avatar
my motor was running fine too before this happend. when you shut off the car is the throttle body fully closed or is it stuck open as if it was idleing @ full throttle? another thing i did was clean the throttle body with carb cleaner.
Old Apr 6, 2007 | 12:30 PM
c r x_s i's Avatar
Default Re: (nomotor)
when i shut the car off.. the throttle is closed...
Old Apr 6, 2007 | 12:33 PM
gator88's Avatar
well im out of gueses now. just sayin what fixed my friends situation. Good luck and all hope ya get it figured out
Old Apr 6, 2007 | 12:36 PM
nomotor's Avatar
yea thats how my car was too, checked the vaccum lines, cleaned the throttle body messed with the idle screw and got it to drop a bit but it was still idleing at 2500rpm and the last thing i did was adjust the throttle cable and it was fixed. just loosen up the throttle cable a bit your not gunna hurt anything and if it doesnt work just tighted it up again.
Old Apr 6, 2007 | 12:59 PM
89efDUSTY's Avatar
did you check the idle screw yet...just go all the way in and start the car if it doesnt start open a little...then keep doing it till it starts...you know if its all the way closed and it starts its leaking somewhere
Old Apr 6, 2007 | 01:53 PM
iskate2's Avatar
check the iacv as it may have stuck open. also check the booster check valve, i have seen them crack in the middle, but that resulted in a minor vacuum leak.
Old Apr 6, 2007 | 02:19 PM
mr.speaker's Avatar
either your intake manifold gasket or throttle body gasket is leaking,,or you have a huge vacuum leak..I dont know what else
Old Apr 6, 2007 | 05:26 PM
Hella_Fresh's Avatar
Default Re: HELP!!!! Car is reving at full throttle and wont stop! (honda89crxsi)
im pretty sure you got all 53 post just from this one thread also............
but
check your idle screw, check intake manifold and TB gaskets. Double check your vac lines.
Old Apr 6, 2007 | 05:35 PM
ALLMOTOR CRX's Avatar
you sure you dont have a rock stuck on the throttle body? take of the intake and check man or it could be the tps if its not adjusted correctly check it green is grond red is constant five bolts orange is from .01 to 5 bolts depending on throttle position adjust it to .45 bolts on the orage wire..
Old Apr 6, 2007 | 05:48 PM
haroldthefly91crx's Avatar
Default Re: (ALLMOTOR CRX)
i just had this problem at it was my TPS, is your "check engine light" comming on?
