JDM ITR Sway Bars
Old Apr 6, 2007 | 07:44 AM
AlienKrOZ's Avatar
Default JDM ITR Sway Bars
Is it worth it to upgrade the JDM DC2 rear sway bar? should i upgrade the fronts to the JDM sway bar also?
Old Apr 6, 2007 | 07:47 AM
RagingAngel's Avatar
Default Re: JDM ITR Sway Bars (AlienKrOZ)
what's your current suspension setup?
Old Apr 6, 2007 | 07:49 AM
AlienKrOZ's Avatar
Default Re: JDM ITR Sway Bars (RagingAngel)
bone stock just jdm 16" wheels and this is the 97 R if that makes a difference from the rack and pin from the 00&01
Old Apr 11, 2007 | 01:58 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlienKrOZ &raquo;</TD></TR><TR><TD CLASS="quote">Is it worth it to upgrade the JDM DC2 rear sway bar? should i upgrade the fronts to the JDM sway bar also?</TD></TR></TABLE>
You need to look at the overall effect that you are after.
In the USA, the tendency would be for people to use a heavier bar and heavier springs in the rear in order not to have to make radical changes to the front suspension.
I have 14K springs in the front and 16K springs in the rear, and then lowered the car enough to get -2.5 to -2.75 camber on the nose, and about -1.75 on the rear.
That was enough for me, and I still have the stock US sway bars.
If you have a stock suspension on your ITR, and you can get a good price on the rear JDM sway bar, then I would just give it a try before I considered making any other changes.
Old Apr 11, 2007 | 05:05 AM
AlienKrOZ's Avatar
Default Re: JDM ITR Sway Bars (George Knighton)
great i'll give that a try since i can probably break even after selling the USDM sway bar
d-yup
Jul 6, 2009 10:04 AM
JDMxDB8
Oct 26, 2006 09:54 PM
mingchi69
Sep 20, 2003 08:44 AM
jdm4me
Mar 20, 2002 04:47 AM
ITR#132
Nov 19, 2001 08:36 PM
