GSR with ITR steering wheel install
Old Apr 6, 2007 | 06:26 AM
sikcrx80's Avatar
Default GSR with ITR steering wheel install
installing a itr steering wheel in a 98 gsr and ran into a prob. the SRS sensor is the way. im thinking just remove it.
just wondering what does everybody do when changing this?
Old Apr 6, 2007 | 10:13 AM
gsr-2nr's Avatar
Default Re: GSR with ITR steering wheel install (sikcrx80)
hopefully you are installing a jdm wheel cause there is no diff b/t usdm itr and gsr wheels . On either wheels you shouldnt have a problem it will bolt right on no problem nothing in the way I threw mine on in 5minutes. I wouldn't remove the sensor not unless you can stand your srs light constantly on.
Old Apr 13, 2007 | 12:49 PM
sikcrx80's Avatar
yes sry it is a JDM one.
well on the sensor the are two nipples that stick out that go into old wheel. what did u do?
does ur horn work still?
Old Apr 13, 2007 | 01:03 PM
MQTT's Avatar
should fit perfectly...all you have to do is turn the nipples to like up
Old Apr 13, 2007 | 01:40 PM
kcjohnnyboy's Avatar
how'd you guys relocated the cruise control buttons or will they not bolt up to the jdm wheel?
Old Apr 13, 2007 | 02:14 PM
MQTT's Avatar
no cruise control...Type R doesn't have it
Old Apr 13, 2007 | 04:12 PM
Default Re: (MQTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MQTT &raquo;</TD></TR><TR><TD CLASS="quote">no cruise control...Type R doesn't have it</TD></TR></TABLE>
sorry, i was referring to putting into a gsr w/ cruise control options
Old Apr 13, 2007 | 04:21 PM
[ iLL ] iNt3GrA's Avatar
Default Re: (kcjohnnyboy)
most people dont run it becuase the wheel does not have it, becuase the type-r does not have it
Old Apr 13, 2007 | 04:22 PM
deadline's Avatar
tuck it away and disconnect bulb (srs)
Old Apr 13, 2007 | 08:47 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (deadline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline &raquo;</TD></TR><TR><TD CLASS="quote">tuck it away and disconnect bulb (srs)</TD></TR></TABLE>
do not do this. Sorry but that is terrible advice.
Correct way to install the JDM SRS wheel on a 96-01 Integra: https://honda-tech.com/zerothread?id=1875083
SRS should function correctly, no SRS light, and turn signal will cancel properly.
Old Apr 13, 2007 | 08:55 PM
BLacK FirE's Avatar
Default Re: (PatrickGSR94)
Beat me too it, I was just about to post my link lol.
Old Apr 13, 2007 | 09:47 PM
gsr-2nr's Avatar
Default Re: (BLacK FirE)
Yes horn works perfectly I just unplugged the cruise control switches and tucked them inside. the only thing is sometimes when you take a gentle right turn and u are using your signal the signal cancel doesn't work you have to manually move the lever
Old Apr 14, 2007 | 07:15 AM
BLacK FirE's Avatar
Default Re: (gsr-2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr-2nr &raquo;</TD></TR><TR><TD CLASS="quote">Yes horn works perfectly I just unplugged the cruise control switches and tucked them inside. the only thing is sometimes when you take a gentle right turn and u are using your signal the signal cancel doesn't work you have to manually move the lever</TD></TR></TABLE>
read my write up (posted by patrick) and that won't be a problem.
Old Apr 14, 2007 | 07:38 AM
kinick313's Avatar
Default Re: (MQTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MQTT &raquo;</TD></TR><TR><TD CLASS="quote">should fit perfectly...all you have to do is turn the nipples to like up</TD></TR></TABLE>
she said nipples
McLude2nR
Jan 27, 2007 10:15 AM
IntegraChick
Jul 25, 2005 09:39 PM
ithrowpoop
Mar 22, 2002 04:01 PM
