msd cap and rotor with ngk wires??
Old Apr 5, 2007 | 11:23 PM
hondatech94's Avatar
Default msd cap and rotor with ngk wires??
hi have a 94 accord ex 4cyc. and i just bought a cap and rotor set..they are MSD and i didn't mean to buy them i just wanted OEM parts to go with my OEM NGK wires. With the msd cap and rotor, it requires me to use a msd coil and not my stock coil. But this new coil (blaster SS coil) is like 50 bucks. Plus i already bought ngk wires....what should i do? use the ngk wires with the new msd coil, cap, and rotor?...are they compatable? or should i return the msd cap and rotor set and order another oem cap and rotor that doesn't require a new coil.
If the ngk wires and the msd ignition won't cause some problem then i guess i'll get the coil....any advice??...please reply fast
Old Apr 6, 2007 | 02:34 AM
Twixle's Avatar
ate my pixel
Default Re: msd cap and rotor with ngk wires?? (hondatech94)
I'd return the MSD stuff and just stick with OEM. There's no practical purpose to have it unless you're doing serious engine mods.
Old Apr 6, 2007 | 05:12 AM
TouringAccord's Avatar
H-T Order of Merit
the stock ignition is fine for a good amount of power unless you are going to be running high into the RPM's (by high I mean something like 8k, and with a stock motor you won't be going that high). Otherwise, OEM ignition is fine to stick with.
You can stick with the MSD parts if you want though. It won't cause any problems and the ngk plug wires will work fine as well. You'll have to get the coil as you've already stated. The coil or the cap should have come with an extra wire to connect the coil to the cap, you may have to cut and crimp the connector onto it though but thats not hard. Also, since you have a 94 EX which has an internal coil, you have to remove the stock coil from the distributor and extend the two wires that are connected to the stock coil to the new external MSD coil. If memory serves me right, the blk/yel is the + and the blu wire is the -. Just extend those to the + and - terminals on the new coil.
Old Apr 6, 2007 | 06:59 AM
Stealthman80's Avatar
Default Re: msd cap and rotor with ngk wires?? (TouringAccord)
fyi the oem wires arent ngk, they are momosumito or somthing like that and there over twice the price of ther ngks, I just bought a new set
siavosh
28
Mar 30, 2010 12:08 AM
roterx7
Apr 1, 2006 05:23 AM
THC07
11
Nov 10, 2005 09:27 PM
redDAinteg
Jun 12, 2005 11:57 AM
