Want to box/silence my compressor cheap, any ideas?
Old Apr 5, 2007 | 11:02 PM
sporkcrx's Avatar
Default Want to box/silence my compressor cheap, any ideas?
Any pointers for making a cheap and easy box or any type of silencer for an air compressor? I barely use mine at home because it's so loud and don't want to annoy the neighbors too much, but I've become so accustomed to them at work I hate not using them. I dont use it much, and it's always off unless I'm using it, so something ghetto could work as long as it doesn't burn down or something. Maybe a small box that I could throw around the motor when I'm using it, and just take it off when not. I dont know.
Old Apr 6, 2007 | 05:53 AM
Bakeoff's Avatar
Default Re: Want to box/silence my compressor cheap, any ideas? (sporkcrx)
If this is a larger one, not a 5 gallon... There should be an easily recognized muffler on it. You should be able to disconnect it, add some pipe in, and extend it away from the compressor. Then you could create some sort of silencer for it. A bucket of sponges, rags, etc.... Just a thought. That or build a box around the whole thing with insulation around it....
Old Apr 6, 2007 | 11:49 PM
red92si's Avatar
I rolled mine into a cabinet space that was comfortably larger than the compressor and lined it with dynamat. Then ran air hose around the garage to a couple of points where I have release fittings to attach other hose when I am working.
Efmysedan
Apr 19, 2019 06:31 AM
Race Egr
Welding / Fabrication
216
Apr 13, 2011 09:35 PM
Nocturnal
38
Feb 27, 2008 08:04 PM
90JPRCRX
Audio / Security / Video
Aug 12, 2004 11:47 PM
B HATCH
May 26, 2004 05:42 PM
