SOHC transmission question.
Old Apr 5, 2007 | 10:18 PM
FOMULA91's Avatar
Default SOHC transmission question.
I bought a Si transmission last summer and I was thinking to swap it out when I do my clutch replacement. Everything went smooth but after trying to fit the HF axel, it just slides in and doesn't catch the gear. I was like WTF but I had no idea so I went back with my old Si transmission instead. The Si and HF gear shaft should be the same but the new transmission seems to be wider so it just rotates without catching the gear. It has the same L3 sticker and it bolts right up but the axel didn't work. Anyone have any idea?
Old Apr 5, 2007 | 10:34 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: SOHC transmission question. (FOMULA91)
wait, so your car is an hf, but you have an old si trans and a new si trans and the new one doesnt work with the old axles but the old one does?
sorry im just kinda confused about what the question is.
Old Apr 5, 2007 | 10:42 PM
HF2ZC's Avatar
It might be a ZC transmission. Those have larger inner axle joints but are otherwise similar.
Old Apr 5, 2007 | 10:45 PM
FOMULA91's Avatar
Default Re: SOHC transmission question. (HF2ZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HF2ZC &raquo;</TD></TR><TR><TD CLASS="quote">It might be a ZC transmission. Those have larger inner axle joints but are otherwise similar. </TD></TR></TABLE>
Yeah i was thinking it was an ZC transmission but I wasn't too sure. So the ZC does have bigger axel joint correct?
Tims Toy 500
11
Mar 15, 2011 06:43 AM
bigwill_2004
Jun 14, 2006 01:58 PM
messeduprex
Mar 17, 2005 01:06 AM
PBrex
Feb 6, 2004 05:13 PM
Art T. Fish L.
23
Apr 6, 2002 09:27 AM
