Complete 95 civic ex coupe doors on a 92 hatch cx
how to wire up 1995 civic ex doors onto a 92 civic cx
the doors brings everything including the wiring hardness
how could i wire that up to make it work
Door brings
+power windows
+power lock
+power mirrors
Door brings
+power windows
+power lock
+power mirrors
i have done this before you need the inside wiring harness also you need the ones that go from the do to the fuse box on the drivers side and you need the harness from the door to the inside of the car on the passenger side there will be 7 or 8 wires on both sides that will have nothing to connect to you need to make a harness for these just color match and youll be fine. you will also need two fuses for the fuse box and youll be done in no time
when they took the doors out the harness that runs between the door and the cars chassis the cut there on both doors what wiring do i need to get?
nickelz34
Oct 5, 2013 05:47 PM
put ex coupe doors with power windows want to make them work in my dx do i need harness from the doo
flatblk
Nov 4, 2006 08:54 PM
Outrun
Aug 25, 2005 12:29 PM
93b18civic
Jan 21, 2004 07:30 PM
