96 JDM ITR 4x114 suspension conversion into 96 GSR. ABS Problem. HELP!
I am planning to swap my stock suspension with a 96 JDM ITR 4x114 suspension and I was wondering how to go about removing/ disabling the abs system since the JDM ITR's are non abs. Can you just pull the abs fuses and call it a day? What would happen if you do so? Sorry for the noob Q's. Thanks
i had an ex coupe with abs i took out the brain and the sensors and my brakes still worked great never had a problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 »</TD></TR><TR><TD CLASS="quote">i put a jdm 5 lug on mine, there are still holes to bolt the abs sensor.</TD></TR></TABLE>
The 96 JDM ITR does not have the holes on the rear brakes for the abs sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmray »</TD></TR><TR><TD CLASS="quote">i had an ex coupe with abs i took out the brain and the sensors and my brakes still worked great never had a problem</TD></TR></TABLE>
I was thinking about pulling the fuse but I was told that I needed to use the brake booster, master cylinder, brake lines, and a 40/40 proportioning valve from an RS. Do I need to change it or should I just pull the fuse.
you dont HAVE to, but its prefered. just remove the fuse and zip tie the lines somewhere that they wont get tangled,
Allmotor2o9
Apr 6, 2007 02:36 PM
Propulsion
Apr 29, 2003 05:55 AM
