D16 Mini Me Swap
Looking to do a Mini Me swap on my 1990 Civic SI D16A6.
I am going to use a P28 ECU so i will need to convert from OBD0 to OBD1.
I have tried searching which helped alot , but i would like a list of all the parts i will need to get.
If anyone could help me out it would be appreciated.
Here is my list so far.
D16z6 head
Various Gaskets
Timing Belt
Spark Plug Wires
Head Bolts
P28 ECU
OBD0 to OBD1 Conversion Harness
OBD1 Fuel Injectors/ Fuel rail?
OBD1 Distributor
will i need to get any other sensors for the OBD0 to OBD1??
Is there anything else i will need, or something on my list that is wrong?
thanks
Modified by alwaysared at 8:33 PM 4/5/2007
D16z6 head
Various Gaskets
Timing Belt
Spark Plug Wires
Head Bolts
P28 ECU
OBD1 Distributor
thanks
I just finished this swap today, only thing else you'll need is a 4 wire O2 sensor and z6 timing belt. btw, i'd use arp head studs for the z6 with the swap, ver' nice. GL with it, mine wound up taking two days o_O.
CyberC1ren
May 20, 2013 06:34 PM
uno-cam
12
Jan 11, 2005 10:00 PM
