Suspension & Brakes Theory, alignment, spring rates....
koni/GC spring rates
Old Apr 5, 2007 | 05:18 PM
90sedan's Avatar
Default koni/GC spring rates
So i know that this question gets asked often, and i have searched but i've found mixed results.
I'm purchasing a set of koni/gc coilovers and i need to know what would be the best spring rate for my application.
- It's going on a 90 civic sedan, that is used for DD with the occasional roadrace. I will be putting in some track time this summer as well, and i will want the set-up to be able to work for that too. Only planning on putting a 2inch drop on it.
With that said, what rates should i go with?
Old Apr 5, 2007 | 09:02 PM
HondaF1Fanatic's Avatar
Tell Ground Control exactly what you just posted here and they should be able to give you exactly what you need. Also, a 2 inch drop isn't insignificant, you may want to think about tophats.
Jon
Old Apr 5, 2007 | 10:19 PM
90sedan's Avatar
Well i know that a 2 inch drop isn't insignificant, but i don't plan on slamming it.
I was thinking about getting the tophats, but wasnt sure if i would even need them for my setup.
Old Apr 6, 2007 | 06:09 AM
2" isn't slammed, but it is low. I always err on the side of caution but depending on the roads in your area you may be fine w/o tophats.
Jon
Bustin_Hatch305
Suspension & Brakes
22
Sep 5, 2012 03:28 AM
Destructive-
Suspension & Brakes
15
Sep 28, 2008 08:36 PM
kisceneret
Suspension & Brakes
Jan 29, 2008 07:47 PM
EBPSI
16
May 4, 2003 06:36 PM
rota426
May 4, 2003 07:13 AM
