help with some wiring and fuel return for my itbs.
Old Apr 5, 2007 | 04:46 PM
IntegraType-R's Avatar
Default help with some wiring and fuel return for my itbs.
The wires i have for my TPS(97 gsr) are
red/black green/black tellow/blue
i'm assuming red = 5 volts , green w/ black strip = ground and the yellow with blue strip = signal
correct me if i'm wrong..
also i'm having problems setting up my return fuel line setup.. is there any pressure on this line leading back to my tank?
I have talked to 92typer about this, in reguards to whether or not, there is fuel pressure in the fuel return line..
i had custom -AN lines made for me at hybrid-racing, which are all great and everything, except the return line fitting thats suppose to go over the opening of the hardline, doesn't fit, its suppose to slid over and able to move up and down while screwing on to the line.. but its not fiting, if there isn't any pressure i was just goin to rig something up or take up ideas, anyone have any?
Modified by IntegraType-R at 8:20 PM 4/5/2007
Old Apr 5, 2007 | 10:10 PM
del_slow420's Avatar
Default Re: help with some wiring and fuel return for my itbs. (IntegraType-R)
im not sure about itbs and the return line but all i wanted to say is dont rig anything up dealing with fuel.. and even itbs.. well no dont rig anything up do it the right way the first time if u get a fuel leak and it just so dripps on the exhaust i hope u no the number for 911
Old Apr 6, 2007 | 07:00 AM
Default Re: help with some wiring and fuel return for my itbs. (del_slow420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_slow420 &raquo;</TD></TR><TR><TD CLASS="quote">im not sure about itbs and the return line but all i wanted to say is dont rig anything up dealing with fuel.. and even itbs.. well no dont rig anything up do it the right way the first time if u get a fuel leak and it just so dripps on the exhaust i hope u no the number for 911</TD></TR></TABLE>
are you retarded?? You people interpet rig in the wrong sense.. why would i spend the massive amount of money i have to jigga rig something, i'm simplely trying to figure out another way..dont post unless you got something smart to say.
Old Apr 6, 2007 | 11:01 AM
Still looking and searching nothing yet..
Just need to color code for the tps wires.. which is which??
Old Apr 11, 2007 | 06:47 AM
Default Re: (IntegraType-R)
expletive u.. talkin bout your massive amounts of money u can kiss my ***... and maybe you should make your self more clear about "if there isn't any pressure i was just goin to rig something up" rig isnt a very great word
jdm_h22
Jan 7, 2016 05:58 AM
Charlie Moua
Mar 22, 2013 05:17 PM
Marcg611
Aug 10, 2010 05:24 PM
White Smoke
Nov 22, 2007 06:33 PM
DJaeMac
Honda Civic (2001 - 2005)
Sep 26, 2007 08:57 PM
