JDM type r vs usdm type r tranny????
Old Apr 5, 2007 | 03:03 PM
boostd ls's Avatar
Default JDM type r vs usdm type r tranny????
Ok i just switched out my brand new usdm type r tranny for a jdm type r tranny i bought from someone what kind of differences should there be it does not seem much different also is there a way to see if the jdm one is authentic or not just wondering how much of a difference it is and if it should be noticable or what any info would be greatly appreciated
Old Apr 5, 2007 | 03:26 PM
doood's Avatar
been there done that
Default Re: JDM type r vs usdm type r tranny???? (boostd ls)
usdm and jdm 96-97 itr tranny's have the same gear ratios and fd
98+ jdm itr tranny's are a hybrid type and consist of b16 1-3, gsr 4-5, and a 4.785fd
Old Apr 5, 2007 | 04:19 PM
boostd ls's Avatar
ok this tranny is supposed to be a 00 jdm itr tranny and is supposed to be the 4.78 final drive but it still tachs almost the same going 60 is there any other way to tell a difference????
Old Apr 6, 2007 | 03:31 AM
boostd ls's Avatar
no help anyone???
Old Apr 6, 2007 | 04:17 AM
94typeR's Avatar
98+ jdm tranny should read LSD N3E
Old Apr 6, 2007 | 08:21 AM
boostd ls's Avatar
the black writing has been rubbed off it looks like i can only see a little bit of it but i can not make it out any other ways??
Old Apr 6, 2007 | 08:56 AM
goldegg's Avatar
If you look at a gear ratio calculator on a 98+ jdm itr tranny vs a usdm tranny they are not off that much in 5th gear, the difference at 60 is minimal.
Old May 8, 2007 | 06:54 PM
martyball619's Avatar
Default Re: (goldegg)
ok i use to own the JDM spec R tranny.. if u bang from 3rd to 4th gear u notice a big drop in rpms.. thats probably the only differece i notice from this tranny.. since the 3rd is a b16's gear and the 4th is from a GSR.. fun tranny overall.. but if u love drag racing.. shifting from 3rd to 4th might be a bummer
Old May 8, 2007 | 06:59 PM
94draglude's Avatar
Default Re: (boostd ls)
http://www.ff-squad.com/tech/temp/Bgears.htm
Old May 9, 2007 | 05:38 AM
skata89's Avatar
The USDM code I wanna say is J4D but I dont know what the jdm one is. Search and youll proably find your answer.
Old May 9, 2007 | 09:19 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (skata89)
I borrowed this image from H-T member Bense. He has several articles about transmissions, and plotted their relative speeds/rpms for us here. You can see that the 98+ JDM ITR tras has a nearly identicle speed as the USDM ITR trans in 4th & 5th. The major difference is the shorter 1st 2nd & 3rd.
And as DC2SiR said, the easiest way to tell the difference will be the larger rpm drop from 3rd to 4th...
Old May 9, 2007 | 03:12 PM
Uncle Willie's Avatar
Why would you swap out a BRAND new transmission for something that could have been the exact same thing?
Old May 9, 2007 | 03:20 PM
kpowerdhatch's Avatar
Default Re: JDM type r vs usdm type r tranny???? (Uncle Willie)
i was wondering the same thing. why swap trans when you dont' know the differences of the two??
Old May 9, 2007 | 04:08 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goldegg &raquo;</TD></TR><TR><TD CLASS="quote">If you look at a gear ratio calculator on a 98+ jdm itr tranny vs a usdm tranny they are not off that much in 5th gear, the difference at 60 is minimal.</TD></TR></TABLE>
5th gear has nothing to do with it, its the FINAL DRIVE that makes the ENTIRE GEARING shorter on the tranny. I used to have a USDM ITR tranny. I later put the JDM 4.75 final drive in it. You can easily and clearly tell the difference in gearing. If you can't notice any difference, then you do not have the shorter final drive.
Old May 9, 2007 | 06:09 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (Hybrid96EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid96EK &raquo;</TD></TR><TR><TD CLASS="quote">5th gear has nothing to do with it, its the FINAL DRIVE that makes the ENTIRE GEARING shorter on the tranny. I used to have a USDM ITR tranny. I later put the JDM 4.75 final drive in it. You can easily and clearly tell the difference in gearing. If you can't notice any difference, then you do not have the shorter final drive.</TD></TR></TABLE>
You don't know what your talking about. The USDM ITR tranny with a 4.7fd installed in it is NOT the same thing as a JDM 98+ tranny. The JDM 98+ tranny has the longer 4th & 5th gear in it from the GSR tranny. As the graph CLEARLY shows, this makes the 5th gear of both US and JDM 98+ trannies nearly identcile. And since the OP was trying to check the difference while cruising in 5th, it makes perfect sense that he cannot seem to tell...
Old May 9, 2007 | 06:55 PM
NABeastRR's Avatar
Default Re: (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">
You don't know what your talking about. The USDM ITR tranny with a 4.7fd installed in it is NOT the same thing as a JDM 98+ tranny. The JDM 98+ tranny has the longer 4th & 5th gear in it from the GSR tranny. As the graph CLEARLY shows, this makes the 5th gear of both US and JDM 98+ trannies nearly identcile. And since the OP was trying to check the difference while cruising in 5th, it makes perfect sense that he cannot seem to tell... </TD></TR></TABLE>
agreed i had a b16 tans. then went to jdm itr 4.7 1rst threw 3rd was like a bike so to say then hit 4th was foreevr but yes daily drivin rpms stayed about the same on highway
Old May 9, 2007 | 07:23 PM
Hybrid96EK's Avatar
Default Re: (94eg!)
Alright, I guess my head was up my *** when it came to overlooking the 4th and 5th gear differences. I thought they were the same. The point still being that he should EASILY be able to tell the difference between the two in first through third. There should be no mistaking it in the first few gears if he did indeed go from a US to a JDM ITR tranny. Agreed?
Old May 10, 2007 | 10:00 AM
NABeastRR's Avatar
agreed i droped 3 ,10ths just from the tranny swap
Old May 10, 2007 | 05:33 PM
Default Re: (NABeastRR)
i miss my R tranny
Kyle244R948
May 12, 2004 03:18 PM
RuffRhyno
Sep 29, 2003 06:08 PM
mattcxb18
Jul 15, 2003 09:45 AM
