1996 JDM ITR Motor with transmission and ECU
1996 JDM ITR Motor with transmission and ECU 1996 JDM ITR Motor with transmission and ECU
$4300 OBO as listed below.
408-887-8641 or email me @ MD_Redstone at yahoo dot com or PM me here
***I WILL NOT SELL THE TRANSMISSION SEPARATE, PLEASE DON’T BOTEHR CALLING ASKING ME TOO, THANKS IN ADVANCE. ***
Some background info on the motor. I purchased the car that the motor was in while I was in Japan, I drove the car before I took the motor out. It then went into my hatchback and has been in since. It has been run on hondata with aftermarket cams, valve springs and retainers, intake, header, exhaust, clutch, flywheel etc. The motor has about 57000 miles on it right now. Last compression check with Toda Cams was 210-205-211-213 and with stock cams it was 230-225-233-235.
Runs excellent, is still in the car right now but I will be taking it out soon, so if you want to see it run before you buy it you can.
The motor will be sold with; stock cams and cam gears using supertech valvesprings and retainers. Stock injectors, fuel rail, regulator. Stock intake manifold and TB. It will have stock JDM P73 Ecu, OEM distributor, cap, rotor and wires. It will also have a Comptech lightweight flywheel and 4 puck copper/Kevlar sprung clutch in there. Transmission is perfect, has never given me trouble.
It will not come with the following; a harness, an exhaust manifold, axles or linkage.
I am selling it because I am going 2 liter and have another motor in the works already. I am willing to ship or drop off with in the bay area; the motor will have to be paid for before shipping or drop off. I can take cash, cashiers check; but it must clear before the deal is complete. Personal check; check must clear before deal is complete. I can also take Paypal but you will need to add 3% to the final price.
purefury
Aug 17, 2005 01:31 AM
